Does the TR-6060 in the GT500 bolt onto 5.0 2011+ Mustangs?
I have searched and will continue to search as I post this.
I apologize if this has been beaten to death.
I want to know if the TR-6060 from the 2007+ GT500 will bolt up to the 2011-2012 Mustang GT with the 5.0 engine and work as if it was there from the factory.
I wouldn't ask this, but I saw some talk about it on this forum and want to confirm that it does.
I know I need a different clutch.
I'm aware that the speedo won't work.
Can I use the GT500 driveshaft?
I'm also looking into the TR6060 used in the BOSS race car. It appears to bolt right up and work as if from the factory.
What else is needed? Do I need the bellhousing or case from the Boss R1?
I know about the T56 magnum conversion kit, I'm checking all of my options when it comes time to replace the MT82.
Thanks so much!
Thanks so much!
Here ya go man. Did the finger work for you. http://www.ddperformance.com/shop/in...p?cPath=108_95
Originally Posted by CoyoteGT
Thanks bro, my only question is which of these work for the 5.0 2011+.
Well I suppose having 600-800hp will solve the gearing issue inherent to the TR6060, otherwise you will have to gear the car very deeply in order to get the same off the line performance the MT82 offers.
Detroit Steel
Jan 17, 2016 08:06 AM
