DIY Oil Change on 2011 5.0
This is just a simple question for those that change the oil themselves.
Can I just raise the front of the car to change the oil or does the car need to be level in order for all the oil to drain???
Thanks in advance.
Thanks in advance.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Thanks in advance.
Thanks in advance.
I disagree about it being a pain. Did mine last week.
Jacked up the front, opened the drain plug so oil drains into the pain., then took the cover bolts out so it swung down.
Then use the ziplock bag trick to capture the oil from the filter and let the filter drop into the bag. Screw on the new filter and you're done.
Not a single drop spilled from the filter change.
The oil filter is also a pain to reach. Once you loosen it the oil will drip all over you, as you try to remove it from the car.
I put a one gallon zip lock bag over the filter, loosen and let it drain into the bag, and then drop into the bag as you remove it. Zip it up, no mess.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
I hate the covers...
Used to have a boat and you would basically suck the oil up through the dipstick. Anyone try this on a car?
http://www.westmarine.com/webapp/wcs...classNum=50402
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
There's a restriction inside the dipstick tube near the top that won't allow a tube larger than 3/16" OD down the hole. You'd be pumping on it forever to get it to pull 8 quarts out. I can't even do oil samples without draining the sump.
I was planning on using the pump on the Mustang the next time I changed the oil. Guess I won't mess with it.
Thanks for mentioning this. I have a pump/tank that I have been using for years on our VW's. It takes about 15 minutes to do an entire oil change on my wife's 2.0 Turbo Passat. The oil filter is on top of the engine, upside down, with a valve that prevents leakage when removed...no mess. The easiest oil change I have ever done.
Not the 2011+ Mustang 5.0, though. It's really disappointing, but I'm afraid it's real. And the filter really wants to make a mess too. The design engineers did a great job on the engine but it's pretty clear they don't do their own oil changes.
Originally Posted by JAJ
Yeah, I've got a vane pump and I've done the family BMW's this way for a decade too, at least until they stopped putting dipsticks in entirely in 2008.
Yes I am switching to Mobil 1 extended performance. That Is a true synthetic. I'll bring the oil to them and take advantage of my first free oil change. And they need to look at a squeak anyway
