Sponsored by:
Sponsored by:
DIY Oil Change on 2011 5.0
Old Feb 10, 2012 | 11:06 AM
dreem363's Avatar
This is just a simple question for those that change the oil themselves.
Can I just raise the front of the car to change the oil or does the car need to be level in order for all the oil to drain???
Thanks in advance.
Old Feb 10, 2012 | 11:11 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Thanks in advance.
You can raise just the front. But I will warn you. Its a pain in the *** with the cover on the vehicle. If it were my car its worth taking it somewhere and letting them change it.
Old Feb 10, 2012 | 11:14 AM
LEwis26's Avatar
I disagree about it being a pain. Did mine last week.
Jacked up the front, opened the drain plug so oil drains into the pain., then took the cover bolts out so it swung down.
Then use the ziplock bag trick to capture the oil from the filter and let the filter drop into the bag. Screw on the new filter and you're done.
Not a single drop spilled from the filter change.
Old Feb 10, 2012 | 11:15 AM
SD CALSPCL's Avatar
The oil filter is also a pain to reach. Once you loosen it the oil will drip all over you, as you try to remove it from the car.
I put a one gallon zip lock bag over the filter, loosen and let it drain into the bag, and then drop into the bag as you remove it. Zip it up, no mess.
Old Feb 10, 2012 | 11:16 AM
Bear Eats King...
Bear ****s Bone
Again I work at a shop. So if I have to lay on the ground its too much of a pain
I hate the covers...
Old Feb 10, 2012 | 11:22 AM
bh6247's Avatar
Used to have a boat and you would basically suck the oil up through the dipstick. Anyone try this on a car?
http://www.westmarine.com/webapp/wcs...classNum=50402
Old Feb 10, 2012 | 11:24 AM
Bear Eats King...
Bear ****s Bone
The dipstick doesn't go to the bottom of the pan. So you wouldn't get all the oil.
Old Feb 10, 2012 | 11:44 AM
dreem363's Avatar
Thank you all for the valuable info!
Old Feb 10, 2012 | 12:01 PM
Hytek's Avatar
+1 on the ziplock bag trick. Be sure to use the larger one though, trust me I learned the hard way.
Old Feb 10, 2012 | 02:35 PM
JAJ's Avatar
JAJ
There's a restriction inside the dipstick tube near the top that won't allow a tube larger than 3/16" OD down the hole. You'd be pumping on it forever to get it to pull 8 quarts out. I can't even do oil samples without draining the sump.
Old Feb 10, 2012 | 03:07 PM
2012GTCS's Avatar
This shield under the car needs to be removed first?! Most you guys just put the front in stands and that's good enough?!
Old Feb 11, 2012 | 06:26 AM
GrabberBlue5.0's Avatar
The shield covers the filter and it doesn't get removed but a few bolts taken out so it can hang down.
Old Feb 11, 2012 | 09:01 AM
2012GTCS's Avatar
Thanks, haven't done the first one yet. Tips are always good!
Old Feb 11, 2012 | 10:54 AM
SD CALSPCL's Avatar
Thanks for mentioning this. I have a pump/tank that I have been using for years on our VW's. It takes about 15 minutes to do an entire oil change on my wife's 2.0 Turbo Passat. The oil filter is on top of the engine, upside down, with a valve that prevents leakage when removed...no mess. The easiest oil change I have ever done.
I was planning on using the pump on the Mustang the next time I changed the oil. Guess I won't mess with it.
Old Feb 15, 2012 | 10:15 PM
JAJ's Avatar
JAJ
Yeah, I've got a vane pump and I've done the family BMW's this way for a decade too, at least until they stopped putting dipsticks in entirely in 2008.
Not the 2011+ Mustang 5.0, though. It's really disappointing, but I'm afraid it's real. And the filter really wants to make a mess too. The design engineers did a great job on the engine but it's pretty clear they don't do their own oil changes.
Old Feb 17, 2012 | 10:29 PM
kylerohde's Avatar
As has been stated multiple times in this thread, put a gallon Ziplock bag over it as you unscrew and your mess is solved.
Old Feb 18, 2012 | 08:08 PM
Muskao's Avatar
Just curious, you going full synthetic on new oil? I too am coming up on first oil change. Most likely Mobile 1 synthetic.. Still shopping though..
Old Feb 18, 2012 | 10:05 PM
2012GTCS's Avatar
Yes I am switching to Mobil 1 extended performance. That Is a true synthetic. I'll bring the oil to them and take advantage of my first free oil change. And they need to look at a squeak anyway
Old Feb 19, 2012 | 01:12 AM
Bmeline916's Avatar
Royal purple!
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Fedupdave42169
Sep 22, 2015 06:29 PM
DarrenGT
Sep 19, 2015 01:00 PM
