Sponsored by:
Sponsored by:
Is the dashboard dimmer wheel 12 volts?
Old Sep 22, 2012 | 03:11 PM
2011mustanggt's Avatar
IS the dashboard dimmer on an 11 GT 12 volts? I need to splice in for the light in my boost gauge.
Thanks!
Old Sep 23, 2012 | 10:49 PM
hawkeye18's Avatar
Looks like I might not recommend taking a large draw off the dimmer supply wiring - it's a digital in/out supplied by a microcircuit inside the SJB:
However, if all you're doing is splicing a little light into it, you should be fine.
Old Sep 25, 2012 | 07:56 AM
thank you! So, does this mean I splice into the Blue/white wire at the dimmer switch or over at the headlight switch?
JonathonK
Sep 24, 2015 06:31 PM
Steve@CJPP
Sep 15, 2015 06:20 AM
