Cobra Jet Intake Help
I installed the Cobra Jet intake manifold a couple days ago on my 11 GT. Cobra jet Intake Manifold, Super Cobra Jet Throttle Body, CJ CAI, Bama Tune. The car keeps going into limp mode and throwing code P2112 and I can't seem to figure out why. Called Bama and they said its not the tune. Any ideas?
Sounds like it might be a bad throttle body. If you bought it new, you may call about a replacement. If not, you might be able to have the actuator motor replaced, but I'm not certain of that.
Edit: Wanted to add that you should check your pinning for the wiring harness if you repinned it. Not sure if a loose wire would throw that code, but might as well check the simple and easy things first.
I redid the wiring, added a connector like Bama suggested, no change. Had Bama send me new tunes, minimal change. Some days the car runs perfectly, and some days it does not. Idk what else to do, just drive it and hope it smooths itself out I guess
Did you install the intake yourself or did a shop do it? Did you reuse the Purge Valve from your stock intake manifold or did you use the new line that was used on the Boss 302 manifold that includes a new purge Valve that needed you to cut and extend the 2 wires and purge valve connector? If you have any questions you can PM me, I installed the Cobra Jet Intake, Dual 65mm CJ Throttle Body and CJ CAI all from Ford Racing, I did the work myself and fortunately all was good on startup, using a Bama Tune.
I'm not sure what kit you're referring to, If it was the Boss Install Kit, it came with a Hose with a fitting on one end that connects to the Driver's side of the intake and on the other end is a Purge Valve, the Tube Assembly attaches to a Bracket that mounts on the rear Drivers Side of the Intake. It's also where the two wires you sliced attached to the connecter on the rear of the Purge Valve.
I'm sure you thoroughly cleaned the top of the cylinder head intake ports and insured that the intake gaskets were good, torqued the intake and fuel rail bolts per spec's, checked all clamps for tightness! Which Throttle Body do you have Dual 65mm or the Mono Blade? If you'd like I'll Private Message you with my Phone #, I live in Clermont, FL maybe we can talk it through and find your problem.
I purchased a Ford Racing Kit from https://fordracingpartsbydonwood.com the Kit Included Cobra Jet Intake, Cobra Jet 65mm Dual Throttle Body, Cobra Jet CAI, the total was $ 1,431.25 including shipping to FL. I did the install on a Base Model GT, it took me about 4 hours, I wanted to look like a Factory Install, It turned out Great, I also loaded a Jon Lund Tune, The car makes Great Power, A Huge Difference!!!!!
12/23/15 07:58 AM
