Sponsored by:
Sponsored by:
Changed her oil this weekend
Old Jul 10, 2013 | 09:34 PM
kylerohde's Avatar
Originally Posted by dmichaels
Oil "wear" and breakdown will vary some with car use/driving style, so I am mostly interested in running analysis to make sure my oil is holding up and to get some data on a couple types of oil. The ford recommended oil change cycle is what, every 7500 miles? I don't ever plan to go that long since I plan on keeping this car a long time (well past the end of the warranty) so I want to minimize wear while I am under warranty. Probably a bit overkill but for peace of mind I will pay a bit extra for an analysis and lower mile intervals for oil changes
Ford's recommendation is to follow the oil life monitor, but Blackstone told me I could go up to 7000 in the last analysis I got easily. That's using full synthetic Castrol Edge with Syntec Tech.
Old Jul 11, 2013 | 07:12 PM
dave07's Avatar
That's a pretty slick idea with the ziploc bag!! I'm gonna do that next time I change some oil!!
Old Jul 12, 2013 | 04:44 AM
It truly is!!!! But alas, I cannot take credit for the idea. Someone else (on this forum I believe) recommended the technique. But yes, it really works, and quite well. I do it for all my vehicles now.
Old Jul 12, 2013 | 10:55 AM
Gtstyles2's Avatar
Originally Posted by FromZto5
That makes sense. I only have 5400 miles but have done 3 or so oil changes. I change mine based on time intervals instead.
Wow that's a bit excessive!! Especially if your using Amsoil which is a "true synthetic"... I'm a neurotic squirrel with my car as well and don't use it much, its a 2011 with 10500 on the clock now and I'm using Mobil 1 and Mobil 1 filter and it says they're both good for 15k but I maybe put about 5k yearly on the car so as a rule of thumb I just change it once a year and that's still excessive
Old Jul 12, 2013 | 12:32 PM
Same... From here on out, I do 1x a year as well. I only put 2k a year tops on mine. I changed her after the first few hundred, just because. Then been 1x a year since. Works out great for me.
Old Jul 14, 2013 | 06:41 AM
Stevedotmil's Avatar
I have had only one oil change since new and I'm due for another one soon as I've been using my car to it's full potential since it's been warm here in Germany. The crappy thing is it's a pain because I have to order the filters unless a dealership here can get them for me. I can pretty much only find RP 5W30 here in small quantities.
Old Jul 14, 2013 | 07:28 AM
Royal purple 5w30? I figured you could order Amsoil or any other big name brand in 5w20, plus the recommended filters???? All via Internet, say amazon?
Old Jul 14, 2013 | 07:37 AM
Twin Turbo's Avatar
I take it the 2011+ Coyote uses a different filter than the 4.6? I say this because the older car shares the filter with the V6 Mondeo, so it's easy to get
Old Jul 14, 2013 | 07:46 AM
Tron84's Avatar
Just hit 1000 miles yesterday. First oil change was back at 400. Anyone doing oil analysis as you change oil?
I've been sending in my oil for analysis every time, except for the first change (knowing it would be full of metals)
The main thing to be watching for is trends over time rather than actual levels. I like the piece of mind it gives me.
Old Jul 14, 2013 | 07:49 AM
Tron's Avatar
Love the jack! I want one!
Old Jul 14, 2013 | 11:34 AM
Me too... It's my fave... Low profile, plus really light (aluminum), and LED light really helps with getting it lined up on jack point.
Old Jul 14, 2013 | 03:48 PM
5W30 because the 5w50 shears down to a 30 anyway if you use motorcraft. The ones that don't are the Amsoil and RP. Track pack calls for the 50.
Old Jul 14, 2013 | 04:47 PM
dmichaels's Avatar
Do you have results posted online anywhere? I'd be interested to see
Old Jul 16, 2013 | 03:00 PM
kylerohde's Avatar
I've done one on my car and will probably do it annually. FromZto5's point is good though...I'm honestly not sure what I'd do if they alerted me to a problem. I suppose I'd go see the dealer, ask their opinion and see what could be done?
I may have a chance to test that soon, with my wife's car. We bought it with 35K on it a couple months ago, but the guy that had it before us had it as a second car and rarely drove it and did zero maintenance in the three years he owned it. As soon as we got it home from Des Moines, I changed the oil and sent it to Blackstone for analysis. Here's what they said:
KYLE: This first sample from your new-to-you Mazda 2.3L was high in aluminum and iron when compared to universal averages, which show typical wear after about 5,500 miles on the oil. We suspect this oil was in use longer than that, based on the high iron. That's the only metal that tracks with time on oil - more miles on the oil means more iron. With aluminum and iron reading high, we might be seeing some piston scuffing too. The viscosity was on target for a 5W/20 and insolubles show good oil filtration. Try running around 5,000 miles next and check back.
So, I did another oil change at 1,000 miles and got this back:
KYLE: Metals look a lot better in this sample than they did last time. To be sure, for just 933 miles on the oil, aluminum and iron are still a little elevated when you consider they're already average (or a little higher) and averages are based on about 5,500 miles on the oil. But, remember that not all the old oil leaves the engine in one oil change. Some oil stays in the engine and that residual oil could explain some of the metal here. If you use another ~1,000-mile interval, aluminum and iron should improve. Stay within 3,000 miles at most.
So I changed it again just short of 3,000 and am waiting for that analysis to come in. What I'll do if they tell me the aluminum and iron are still way high, I'm not sure. I'm not going to tear down the motor and replace the pistons, and the car's out of warranty, so it might just be something for me to worry about
Just got another update from them so thought I'd share:
KYLE: Your hopes have come true! Iron and aluminum are indeed back to normal levels, even as you've started lengthening your oil run a bit this time. As we've pointed out in the past, averages are based on ~5,500 miles of oil use for this type of engine, so it remains to be seen if metals will hold steady on a longer oil run, but if you're comfortable with ~3,000 miles or so on an oil change, that'll help keep the metals in check. You could probably run longer if things stay steady from here. The slightly low viscosity isn't an issue, so just check back to monitor. Getting better!
If anybody wants to see the full report plus all the analysis data from all three reports, here's a link: https://docs.google.com/file/d/1CDPP...it?usp=sharing
Autotooner
Nov 24, 2017 12:42 PM
ricky1728
Feb 11, 2016 07:25 PM
DerekShiekhi
Sep 30, 2015 06:59 AM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
