Camber
Camber
What are you guys using to correct camber after lowering. I've only seen the maximum motorsports plates, and the qa1, but gotta have the qa1 shocks and springs for them.
Any cheaper route than the MM plates?
If you switch to the 05-10 shocks, you can use the other options -- Steeda plates (they also have the spindle mount ones, don't know if they'd work) or the J&M.
http://www.hotpart.com/shop/index.ph...ct_detail&p=64
http://www.steeda.com/store/steeda-h...d-mustang.html
See Strano's site for explanation (and purchase...)
http://www.stranoparts.com/partdetai...D=75&ModelID=5
Yes, there is a cheaper option. Do nothing, as a result of the slightly higher negative camber, your handling will improve. If all you do though is drive in straight lines and don't corner much, then your front tires may wear on the inside a little faster. I'm personally using Eibach camber bolts, but to get even more negative camber, not take it back closer to zero.
True, although most that lower are also swapping out springs/shocks/struts, so if you do that, just get the 05-10 parts and you're golden
Exactly! I use my plates to ADD more camber (turned 180 degrees from the direction to correct the camber from the lowering) and can get even more for the track by pushing it all the way over to about neg 2-3.
MRGTX
Aug 15, 2015 07:45 PM
