Sponsored by:
Sponsored by:
Brembo or other rotors
Old Oct 21, 2012 | 04:37 PM
mikeyt03's Avatar
I want cross drilled rotors. I know that slotted rotors would be better, but my question is, are after market cross drilled rotors going to be at least as good as the stock brembo rotors I have? If so, do you have any recommendations?
Old Oct 21, 2012 | 05:35 PM
Ponywars's Avatar
Why do you want to change them?
Old Oct 21, 2012 | 05:40 PM
mikeyt03's Avatar
My brembo rotors are rusting and I like how cross drilled rotors look.
Old Oct 21, 2012 | 06:58 PM
TommyV's Avatar
http://www.summitracing.com/parts/EBC-GD7426/
http://www.summitracing.com/parts/BAE-2261031/
The Baer's will save you about 5 lbs. per rotor.
Old Oct 22, 2012 | 02:56 AM
autobred's Avatar
the black dimpled/slotted are still on sale..wish I had known about these
http://brakeperformance.com/brake-ro....php?did=12694
I went with stillen after reading about an install in this forum
https://themustangsource.com/f800/br...review-501150/
Old Oct 22, 2012 | 06:00 AM
MRGTX's Avatar
Like... rusting around the hub or on the surface of the rotor?
Either way, so long as you have adequate thickness and no warping, the issue is probably only cosmetic. The surface rust will be gone as soon as you step on the brake pedal to stop the car.
Old Oct 22, 2012 | 06:03 AM
mikeyt03's Avatar
Around the hub and in the vented part of the rotor. It is just cosmetic, and I could paint them I guess.
Old Oct 22, 2012 | 06:04 AM
cpotts13's Avatar
I have the bear eradispeed 2+ rotors and they are nice. :3 they will rust though hahaha.
Old Oct 22, 2012 | 06:25 AM
Scuba-Matt's Avatar
I would stay away from drilled. If you like the look go with dimpled.
On my Lightning this is what every rotor in the set of high end rotors looked like after 10k miles. Yes there were a lot of 130 mph + 1/4 mile stops. But they shouldn't have cracked. This is the second set to do this. 2 Different company's
Old Oct 22, 2012 | 10:53 AM
JPMotorSport's Avatar
Yeah friends love to tell me to not go with drilled on a daily driven car.
Fred_Garvin
Sep 17, 2015 04:10 PM
Sep 16, 2015 06:44 PM
Evil_Capri
Motorsports
Sep 11, 2015 08:04 PM
earl610
Sep 6, 2015 05:48 PM
