Boss 302 Manifold
Boss 302 Manifold
My first post.
Im considering purchasing the boss manifold for my car. But ive read in various forums and sources that its pretty much worthless unless you are running a power adder. Has anyone heard of this? Also in the market for some long tubes. Any recomendations on a good brand?
There are a lot of opinions out there on if the Boss manifold is worth it or not. Ultimately it's up to whether you want it or not, so look into the reasons why you are considering it and make your decision based on your personal preferences.
Most people tend to agree on this: If you take a car and put the Boss Mani on it and leave it otherwise modded (or not modded) the same, you will gain some top end horsepower but lose some low end torque. It's your decision whether or not that trade off is worth it.
If you're adding a bunch of power with forced induction, with these cars, you probably wouldn't be able to notice the torque loss or the power gain from the Boss manifold in daily driving.
As far as headers go, once again, do some research on your own based on what you want and the rest of your exhaust set up, but IMO you can't go wrong with Kooks or ARH. Both brands are pretty pricey though.
As stated above, it is up to you on the Boss IM.
As far as the torque loss, I think that depends on the tuner.
Are you Auto or Man transmisison? If an Auto, and keeping the stock CAI (Filter box), then you will need to purchase the Boss Intake Tube. This is the tube that runs from the TB to the CAI. It is usually included in the install kit if you purchase that.
As far as LT Headers, do your research. I run the JBA LT Headers & Catted H Pipe. Fitment is spot on, and tucks under nicely, and priced great.
Even though it is much more then the Boss manifold I would look at the Cobra Jet instead since several people with Bosses are switching or trying to switch to it.
A Man Just Needs Some....
Sounds like he just needs more seat time. Possibly better tires in the rear or just a better launch. Experimenting with shift points. Pushing every gear to red line actually loses some time unless he's set up for it correctly. Bama tunes leave hp on the table but are pretty safe. These engines are not forgiving with an aggressive tune unless its perfect. I'm sure Bama doesn't like buying people motors. I met a guy not long ago with a very well set up new GT auto. Nothing extreme except for slicks and a 100 shot. Running low 10's all day long. You have to get a game plan of what you want out of your car instead of just throwing mods at it.
17 hours later, mine was finished in my garage on jack stands.
As far as difference, it is quiet. I run Boss 302 AB, and still have the resonators in the OTA pipes. I have been told to remove the resonators or change the AB's.
Power wise it is great.
Make sure you don't need 02 bung plugs. I needed 2 as JBA had 3 locations for my 02 sensors, and did not include them in the headers.
Believe this thread talks about the CJ manifold. http://www.svtperformance.com/forums...-interest.html
I'm running 12.33 times at 115 MPH in 1800 DA in an automatic with a Bama tune. And I have at least 100 trips down the track with it with no issues. I ain't taking my chances with any so-called "better" tunes unless there's proof it's going to survive hundreds and hundreds of runs.
Evil_Capri
9/11/15 08:39 AM
