Anyone still offer a ghost cam tune?
As the title says. I know you can get the lopey idle through the track cal from Ford, is this the only option these days?
Thanks.
Thanks.
I have the Track Cal. I currently have the Boss Quad Exhaust with the Restrictors removed and stock mufflers. I have heard most all of the competition (Camaro, Challenger Etc) with different exhaust setups. Plus lots of new Mustangs. Again with different setups. I think mine sounds EXPONENTIALLY better at idle than anything I have heard in person. I will eventually go with the GT500 mufflers to turn the volume up a bit. But the Lopey Idle sounds so good in person! I also liked the factory warranty and ability to keep the Catalytic Converter with the Track Cal. Money well spent in my opinion.
I am right there with 14Glassback. I have a similar exhaust setup but with the Trackey tune (Basically the same as the Track Cal Tune but tied to a special key). The trackey tune allows me to go back to the stock tune by swapping the key. I also have the Boss Quad Exhaust, but with the QTP electric cutouts to control the amount the Boss Quads are open. Typically run the side exhaust about 1/2 to 3/4 open. With my Roush Axle backs I get a mean deep throaty tone. Nice rumble, lots of crackle and pop on deceleration with plenty of engine braking. Still it can be semi-quiet while cruising the freeway, even with the side pipes wide open. The Lopey idle is simply amazing, even does a slight movement of the car at idle. I have even had a few mechanics catch me in a parking lot and ask what cam setup I have in the car. Love the change in my car from the stock tune and rarely use the stock key. Nothing wrong with the Ford Racing tune, glad I went this route. Car is much more responsive and even bigger thrill to drive.
+1 for the Ford Racing Tunes.
Did I misread the question?
I have the TracKey. It's slick and I highly recommend it.
If I had another stock Mustang that wasn't a 2014.5 manual, I'd go with the Track Cal. It's safe and almost as slick.
But if you have mods you can't use these. I heard that Ford Performance has a patent on the lopey idle tune and Lund is the only company licensed to use it.
1969 Boss429
4/12/17 02:31 PM
