For anyone that installed Koni sports themselves
I just attempted the rear shock install. The instructions included indicates 37 ft/lbs for an M12 (which is what the threaded piston measures). When I attempted to torque the nuts the rubber bushings got so compressed that the spilled out way past the washers, in fact I couldn’t get them to 37 ft/lbs, tried 26 ft/lbs (spec’ed for M10) still could couldn’t get there (as in the torque wrench didn't click) as the washer still looked way too compressed. I finally settled on the pics below.
As you can see the rubber bushings still exceeds the width of the washer but this amount of bushing compression is as comfortable as I feel they should be compressed. Would you believe this is 10 ft/lbs? Am I doing something wrong? I used two different torque wrenches (one of which was recently calibrated to +/- 1%), same result. What do you guys think?
I did the sports myself, and the koni instructions say not to mushroom the bushings which is what happens when you torque them to the Ford spec 37ftlbs. I just did it by eye then try torquing it to 20lbs and see if it still looks like that if so back off a few pounds.
Edit: Sorry I didn't see your other post, the pictures look about right. You could try a little more lbs and see how it looks. Remember, as long as they don't look squished.
Well, no mushroom, sorry for using the wrong description. Based on the pictures it shows you the squished bushing with a big X and then the way you have it with a check or ok. If it doesn't say ok or have a check but says something else I apologize in advance because it's been a while.
I've never torqued shocks. Always tightened them so the bushing slightly exceeds the washer - because that's how they looked from the factory. Couple of hundred thousand miles and no issues.
Yes I have them. I did mine up until they just bulged past the washer, which is a good match to cdynaco's advice.
Just looked at the fronts, no instructions, pictograms or otherwise, just a bag with 2 nuts, 2 lockwashers and 2 plastic split washers...What do I do with the plastic split washers? Besides the instructions am I missing any other parts?
M3hunter
9/10/15 09:26 AM
robjh22
9/8/15 12:31 PM
