Sponsored by:
Sponsored by:
4.10 on automatic mustang 5.0 2012
Old Nov 9, 2011 | 01:50 AM
Dan11111's Avatar
I'm afraid to go with 4.10.
Won't my 1st gear be too short and useless?
Old Nov 9, 2011 | 10:15 AM
BlackMamba03's Avatar
You'd have to get a tune. The tune would address all your shifts to go with the new gears. American Muscle has 4.10's in their Grabber Blue test car and they love it.
Old Nov 9, 2011 | 01:36 PM
Dan11111's Avatar
I've already got a tune from AM. I'm looking forward to install boss intake manifold with 4.10 gears. I guess how they will be working together...
Old Nov 9, 2011 | 07:27 PM
Ok well once you install the intake and gears, you'll need another tune. It'll address your new mods and your car will shift fine.
Old Nov 11, 2011 | 12:53 AM
Dan11111's Avatar
What about performance of 4.10?
Old Nov 11, 2011 | 04:14 AM
AlsCobra's Avatar
A Man Just Needs Some....
It should be great. I would try and find a custom dyno tuner though.
Old Nov 11, 2011 | 09:52 PM
going for broke's Avatar
Too much gear for a street going car. First gear would be absolutely useless. There is such thing as too much gear and this would be it. Your talking over 20% more gear then stock. Thats a bunch. Unless your living life a 1/4 mile at a time I'd say 3.55's would be all you would ever need IMO.
Old Nov 11, 2011 | 10:07 PM
yugoboss's Avatar
4:10 would be awesome for that auto.
Old Nov 16, 2011 | 09:13 AM
825LTRGT's Avatar
This explaination is using antique reasoning from the old days. The towering intellects probably have a reason for going with a 4.10.
My understanding of the major issue with 4.10's is that the trans must shift into 5th gear before the end of the 1/4. Fifth gear is .87.
And if you get significant tire spin in 1st or 2nd, then the trans goes into limp mode.
On the street, a 4.10 gear with a 4.17 1st gear is useless. The potential for the tires breaking loose is too high and you are not in the power band very long.
To put it in Fox body terms, the 1st gear in the WC T-5 is 2.95. The rear gear needed to get the same multiplication factor found in a 6R80 (with a 4.17 1st gear and a 4.30 rear gear) is 5.79. Who needed to run a 5.79 then? Nobody.
Using my antique calcs from the old days the best gear for this setup is a 3.55 (actually a 3.68) to go through the traps at 7000 and a 27.25 inch tall tire and not shift into 5th.
FWIW, to go through the traps at 6k with a 1.14 4th gear, the rear gear is a 3.16.
Hmmm. If I get a 6r80, I'd experiment with tire height first.
MRGTX
Apr 17, 2023 06:54 PM
Ecostang
Nov 3, 2022 08:50 PM
PonyShow
V6
Nov 17, 2017 02:00 PM
Kestral
Jul 29, 2015 10:26 AM
