2011 Suspension: Anybody working on tubular K-members or A-frames??
Has anybody caught wind of any of the suspension companies, like BMR, working on lightweight tubular replacements for some of those big suspension?
I don't see any real chatter about these types of things yet... and to be honest, I'm a bit hazy on their benefits besides weight reduction.
I started thinking about this due to the clunking I have in my front lower control arms after lowering... might consider a full upgrade if it is worth it.
Any and all comments/experiences invited!
Clunking noise? Did you re-use your stock strut mounts? The oem 2011 GT upper strut mounts have been known to make popping and clunky noises on lowered vehicles.
I have 2011 GT500 strut mounts because I swapped shocks/struts to D-Specs. Interesting thought, though. I hadn't seen much about the GT mounts making noise.
BMR has a full line of suspension parts for the 2011+ mustangs including upper/lower control arms, a-arms, k-members, panhard bars, support braces, driveshaft loops, etc. check our their website for more info. hope this helps.
are you sure? their website has options for 2011 k-members in all their different styles. for example, this is the one id recommend for people using superchargers and want to upgrade from the stock k-member....
https://securec20.ezhostingserver.co...&productid=151
it was talked about on the s197 forum. bmr said it was not ready yet would be a while.. send them a email..
did just run across this.http://www.svtperformance.com/forums...-k-member.html
will try to find the other link.. found it, not s197. but here. http://www.modularfords.com/forums/f...h-pics-178158/
beers
yep,
beers
beers
hmmmmm, ill have to look into it more. thanks for the tip.
