Sponsored by:
Sponsored by:
2011 GT occasionally not "catching" on start-up? (Stock tune)
Old Mar 22, 2011 | 08:07 AM
MRGTX's Avatar
So this has happened three times now.
I'll go to start the car and the motor just spins over without firing. I always turn the key off after about 2.5 seconds of cranking and let it sit for a moment before trying again. The first two times, it has fired right up on the second attempt but the other day at the gas station, it took three tries and I started to wonder what the hell is going on and if this might strand me at some point.
The car has been warm each time this has happened. So far, cold startup has been normal.
3,700 miles, stock tune, intake, etc. No CEL or any other evidence of a problem.
Any ideas? I'd really prefer to not take it to the dealership and put my car through hundreds of start up cycles while they try to recreate it.
Thanks for any advice!
-Mike
Old Mar 22, 2011 | 08:11 AM
DaSFGiants4Life's Avatar
Many of us had this problem. So far after doing the theory in this thread I haven't had any problems ( knock on wood )
Here's the thread for this.
https://themustangsource.com/f804/st...anking-491522/
Old Mar 22, 2011 | 08:15 AM
MRGTX's Avatar
Thanks, DaSFGiants! I really appreciate it.
I missed that thread... I'l read up. Glad that you were able to (possibly) solve the issue!
Old Mar 22, 2011 | 08:18 AM
No problem! Hopefully it works for you. Do keep us posted if your still having issues with her.
Old Mar 22, 2011 | 08:40 AM
MRGTX's Avatar
Will do. There is some logic to letting the computer cycle before twisting to the start position... but it doesn't explain why it happens so seldom.
We shall see...
Old Mar 22, 2011 | 09:27 AM
pony racer's Avatar
We shall see...
it also gives the fuel pump time to "prime" the injectors.. which can also cause the starter run on.. my 95 would do the same thing if i didnt let the fuel pump pressure the line.. i think its a combo of the 2...
Old Mar 22, 2011 | 10:35 AM
FordService's Avatar
-Mike
Hey MRGTX,
My name is Deysha with Ford Customer Service. If you do not think it has to do with the starting feature in your mustang, please make an appointment with your Ford dealership. Then message me with your mileage, VIN, dealer, and contact info so that I can escalate this for you.
Deysha
Old Mar 22, 2011 | 11:09 AM
Originally Posted by FordCustomerService
Hey MRGTX,
Deysha
Hi Deysha
Would it be possible to escalte this to ford in regards to this issue? There has been MANY members here having the same problem. There is something wrong when 20 or so members are having the same issue. Here are the other threads in regrds to this matter. Your assistance is much appreciated.
https://themustangsource.com/f726/st...-issue-485021/
Old Mar 22, 2011 | 11:12 AM
And if we take it to the dealer we will always get this response from them 9 times out of 10.
" .. can't replicate issue."
Old Mar 22, 2011 | 11:40 AM
I definitely understand where you are coming from DaSFGiants4Life. As we all know, that is the first step is to bring it in. I would recommend them to at least call in to the Ford Customer Relationship Center at 1-800-392-3673 after going to their dealer or contact me via private message as everything gets looked at on a case by case basis.
Deysha
davelev213
Aug 27, 2015 01:54 PM
DarrenGT
Aug 19, 2015 08:22 AM
2011gt5.0
Aug 7, 2015 11:20 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
