4.6L GT Modifications Place to discuss the 4.6L 2010 motor based modifcations.
Verts with shaker scoops?
Old Oct 4, 2013 | 08:26 AM
SpeedCostsMoney's Avatar
I have a 2010 GT Vert and want to get the AM Shaker Scoop.
http://www.americanmuscle.com/cdc-shaker-10gt.html
My only concern is losing the shock tower brace. Do any of you know if they make one that works with the shaker scoop? It looks like you have to remove the stock one to get the scoop to work with a convertible. I do not want to lose the stability since it is topless.
Old Oct 4, 2013 | 12:11 PM
AMWill's Avatar
Former Vendor
SpeedCostsMoney,
You're right about installing the Shaker Scoop- you will have to remove any strut tower brace currently installed. However, there are other ways to stiffen the front of your vert without using a STB. Whiteline makes a Front Control Arm Brace that provides similar stability as a STB!
Check it out when you have a chance. It's the perfect solution for you stability concern!
Shane
Old Oct 4, 2013 | 12:48 PM
Cool! Then those are my next two mods!!!
Gigantor
May 11, 2023 07:31 PM
duppycat
Feb 16, 2019 08:36 AM
TerryD
Sep 28, 2015 11:48 AM
UOP Shadow
Sep 27, 2015 07:24 AM
