Verts with shaker scoops?
I have a 2010 GT Vert and want to get the AM Shaker Scoop.
http://www.americanmuscle.com/cdc-shaker-10gt.html My only concern is losing the shock tower brace. Do any of you know if they make one that works with the shaker scoop? It looks like you have to remove the stock one to get the scoop to work with a convertible. I do not want to lose the stability since it is topless. |
SpeedCostsMoney,
You're right about installing the Shaker Scoop- you will have to remove any strut tower brace currently installed. However, there are other ways to stiffen the front of your vert without using a STB. Whiteline makes a Front Control Arm Brace that provides similar stability as a STB! Check it out when you have a chance. It's the perfect solution for you stability concern! Shane |
Cool! Then those are my next two mods!!!
