4.6L GT Modifications Place to discuss the 4.6L 2010 motor based modifcations.
Need some brains here !!
Old Sep 11, 2011 | 06:40 PM
bobbyprice's Avatar
K, I have a 2010 Kona Blue GT Premium w/trac pac, 5-speed, I lowered it with an eibach prokit, used Tokico HP struts & shocks, new GT500 strut mounts, as well as BMR boxed lca's, non-adj uca, w/ relocation brackets, BMR single adj panhard bar w/ new panhard brace, I put Boss 338 20" wheels w/255-35-20,285-30-20 tires on them, now when i had it aligned all was well except for the dreaded swaybar endlink bump, new adj on the way for that, but problem is this, I drove the car roughly 250-325 miles with no abnormal sounds other than links, and now I have a whine which appears to come from rearend at highway speeds when warmed up, I need some input to what you guys may think it could be, pinion angle? Pinion bearing? Carrier bearings? I am totally lost, and Ford will not touch it. Thanks
Old Sep 11, 2011 | 09:17 PM
CO_VaporGT_09's Avatar
If you didn't put in a one-piece driveshaft it shouldn't be the pinion angle, as the two-piece allows a fair amount of leeway, but you might want to get an angle measurer and check for sure, as whining from the rear is often the diff.
http://www.steeda.com/store/uploads/...ol-arm-1-1.pdf
Old Sep 11, 2011 | 09:23 PM
bobbyprice's Avatar
Thanks, What was strange is how it started after a road trip I made down to Mobile, Al. hoping its not to bad.
Old Sep 12, 2011 | 08:09 AM
Alabama will have that effect...
Old Sep 12, 2011 | 09:06 AM
bobbyprice's Avatar
Yeah it will...... Hwy 45 is rough as he** too. Now im thinking internal bearing problem, because no vibration or grinding, just an aggrivating whine above 55-60 when warm.
Blip
General Art
Oct 6, 2007 06:06 AM
Enyo
Off-Topic Chatter
Jun 17, 2007 05:10 PM
jacostang
Mar 24, 2007 05:00 AM
drift35
Mar 17, 2005 01:37 PM
