PTWA Process for 2011 Aluminum Block Article/Video
Old Feb 10, 2010 | 02:12 PM
bpmurr's Avatar
Here is a nice article with video showing the PTWA process.
http://jalopnik.com/5467038/the-ford...he-nissan-gt+r
Old Feb 10, 2010 | 02:24 PM
PTRocks's Avatar
Sweet! Thanks for the link.
Originally Posted by jalopnik
Believe it or not, amortized out, this process is actually cheaper than a pressed-in cylinder liner. These machines can line virtually any bore diameter quickly and cheaply; and the process is both fast and easily scaleable. As an added bonus, it's accurate enough that no piston-to-bore matching is required — the factory uses one size of piston, period.
Old Feb 10, 2010 | 02:45 PM
stangfoeva's Avatar
MOTM Committee Member
I thought Ford was incapable of being on the cutting edge of technology? And isn't every other manufacturer more progressive? [/sarcasm]
nice vid
Old Feb 13, 2010 | 05:30 AM
SonicBlueMustang's Avatar
Wow good video! Seems as tho Ford is really bringing it on. The stock should be higher imo,
Old Feb 13, 2010 | 01:43 PM
MARZ's Avatar
Swamp Donkey Aficionado
No, you guys have it all wrong. This is typical Ford, mindlessly wandering along, building substandard cars. This has got to be a Toyota or Honda innovation! /sarcasm
Old Feb 14, 2010 | 09:16 AM
blksn8k's Avatar
Funny thing is, Nissan is using this technology on the V6 in their GTR, but they are licensing the process from....FORD!
Old Feb 14, 2010 | 11:16 AM
hi5.0's Avatar
So the "spray bore" 5.0 Cammers were the precursors to this, or was that a completely different process? Too bad over-boring won't be possible - yet. Would hate it if the engine were to somehow fail (you know somehow someone out there will throw more power at it and find a way) and the bores get scratched/gouged.
Old Feb 14, 2010 | 01:15 PM
Red Jay's Avatar
im guessing thats the iron unit on the left..
Old Feb 14, 2010 | 06:42 PM
montreal ponies's Avatar
Bahhh, i've got all the tools at home to do the exact same thing. Way 'da go Ford.
Old Feb 9, 2013 | 08:45 PM
Lemmy's Avatar
I hate to be cynical, but this reminds me of a glorified Slick 50 commercial.
Old Jun 11, 2013 | 12:31 AM
Lemmy's Avatar
Iron block on the left looks fine to me.
Old Jun 18, 2013 | 12:42 AM
kcoTiger's Avatar
It will require a new block if the bores are damaged, but make no mistake, this is no slick-50 gimmick. This process is extremely effective at removing weight and allowing the motor to function properly. I'm glad my 5.8L went through this process.
May 3, 2026 05:42 AM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
MustangConvert11
Sep 30, 2015 08:01 PM
