Max rear tire size
Old Feb 22, 2019 | 09:27 PM
Ingo's Avatar
Max rear tire size
I own a 2010 GT500 with the stock 19 inch wheels. Would like to know what the max tire size for the rear wheels would be. Currently using 285, Nittos.
wondering if 305s would fit? has anyone tried going that wide?
Old Feb 22, 2019 | 09:59 PM
Gabe's Avatar
Yes a 305/35/19 will physically fit onto those 19x9.5 rear wheels, but it's not recommended.
The sidewall bulge will make it so you won't really get a 305 contact patch.
You're better off running a 285 with a better compound. It will fit more squarely onto that wheel, give a better contact patch, and stick better due to the better compound.
Old Feb 22, 2019 | 11:05 PM
shaneyusa's Avatar
For a 9.5 inch rim the suggested max is 275. I know they run the 285's on them so you could get away with a 285. Sound like that is what you are running... I probably would not go any wider than that. So 285/35R19 is you best bet unless you want to move to a wider rim.
Old Feb 24, 2019 | 10:31 PM
Ingo's Avatar
I see, thanks for the info!
NJStang
2011 - 2014 GT/CS
22
Dec 17, 2021 08:52 AM
MikuhlBrian
Jan 20, 2014 11:49 PM
06GT
Jan 6, 2007 01:43 PM
S197 V6
05-09 Exterior Modifications
Sep 19, 2006 06:26 PM
blacky3.2
Nov 13, 2004 04:53 PM
