Max Front Tire Width
Old Jan 3, 2007 | 02:02 PM
06GT's Avatar
Smile Max Front Tire Width
Guys:
I've got a set of GT500 18x9.5s in my garage now, I want to put 285s on all 4 corners.
Is anyone running 285 or larger up front?
Do they rub, and how much? Any problems?
Let me know if there are any other issues.
Thanks,
Old Jan 3, 2007 | 02:07 PM
RedDragon777's Avatar
i say 265 in front 285 in the back
Old Jan 3, 2007 | 02:08 PM
94tbird's Avatar
ive got 275s in the front and i have very minor rubbing, but only hen the wheel is turned to its limits
Old Jan 3, 2007 | 02:10 PM
samckernan's Avatar
Mine are only 255's up front. I have 285 on the back. I wanted something a bit narrower up front. As for rotating... I figure when I replace the second set out back, it'll be time to get new ones on the front as well.
I've heard some putting 275's (but not 285's or larger) on all four without any problems.
Sam
Old Jan 3, 2007 | 02:21 PM
hey drew are you going to reuse your fanblade center caps on the GT500 rims and will they even fit
Old Jan 3, 2007 | 09:41 PM
06GT's Avatar
They won't fit the new wheels, but I'm going to keep the Fanblades and probably put Toyo RA1s on them for full-track use....so I won't be parting with them
Old Jan 3, 2007 | 09:43 PM
06GT's Avatar
Cool, cool....
I could settle for 275s all-around as well...
I just want to do same tire size on all four wheels for rotation, and to not induce any more understeer by having front tires smaller than rears.
I plan to track the car again in March...probably a few more times during the year as well
Old Jan 4, 2007 | 02:12 AM
Hollywood_North GT's Avatar
Closet American
Saleen does 275s on all four corners on the S281 - doesn't seem to be a problem. Course, those are 20" wheels they use.
Old Jan 4, 2007 | 05:21 PM
Infinity's Avatar
285's all around has been done many times, and I think that's what Steeda uses. Official_Style uses 285's on 18x10's on all four, and he loves them.
Old Jan 5, 2007 | 09:35 AM
06GT's Avatar
Great! Thanks for the info, guys!
Old Jan 6, 2007 | 01:43 PM
428CJ(R)'s Avatar
You'll want to check the clearance with the struts and upper sway bar end links. I have 285/40s on 18x9.5 rims with +45 offset. There is about 3/8" clearance between the tire sidewall, the strut tube and the end of the upper strut link. I haven't had any problems but there is minor rubbing on the fender liner when the wheels are turned to the limit. Tire Rack lists offset for the 2007 GT500 18x9.5 at +47 so you may have slightly less clearance.
pretender
Aug 24, 2015 01:59 PM
MELLOWYELLOW06
Jul 21, 2015 11:59 AM
