CHANGE ENGINE OIL SOON message...
Old Aug 20, 2011 | 05:38 PM
1 COBRA's Avatar
... comes on with every start. It has happened for the last few days.
The oil and filter were changed less than 2000 miles ago. I reset it each time but comes back. Is there any way to remove this message other resetting each time? Thanks.
Old Aug 20, 2011 | 05:42 PM
11SHELBYGT500's Avatar
The only way I know of is to have a dealer reset the "oil life"
Old Aug 20, 2011 | 06:25 PM
There should be instructions in the owners manual to reset it yourself. I do it on the Fords I have where I change my own oil but I don't remember the procedure.
It's more detailed than just hitting the reset button.
Old Aug 24, 2011 | 07:49 AM
FordService's Avatar
Hey 1 COBRA,
2k7gtcs, is correct. Here are the steps that show in your manual: To reset the oil monitoring system to 100% after each oil change perform the following: 1. Press and release SETUP to display “OIL LIFE XXX% HOLD RESET = NEW”. 2. Press and hold RESET for two seconds and release to reset the oil life to 100%. You can also access your manual here: http://owner.ford.com/servlet/Conten...&model=Mustang.
Deysha
Old Aug 24, 2011 | 09:58 AM
Originally Posted by FordCustomerService
Hey 1 COBRA,
2k7gtcs, is correct. Here are the steps that show in your manual: To reset the oil monitoring system to 100% after each oil change perform the following: 1. Press and release SETUP to display "OIL LIFE XXX% HOLD RESET = NEW". 2. Press and hold RESET for two seconds and release to reset the oil life to 100%. You can also access your manual here: http://owner.ford.com/servlet/Conten...&model=Mustang.
Deysha
Thnx Deysha I just got learned.
Old Aug 24, 2011 | 11:37 AM
1 COBRA's Avatar
Thank you all, I appreciate your replies.
Old Aug 25, 2011 | 09:22 AM
No problem, guys! I'm here to help!
Deysha
Old Sep 1, 2011 | 05:52 PM
1 COBRA's Avatar
I finally had spare time last night. It took less than a minute.
Smurfette is happy again.
Mpaps
Oct 11, 2017 08:06 PM
dblhelx
Oct 6, 2015 08:08 PM
mustangsally_
Sep 18, 2015 05:35 AM
Evil_Capri
Sep 11, 2015 08:39 AM
