2013 Shelby GT500 hits the dyno..
How about those " stock " #'s !!!
.http://www.youtube.com/watch?feature...&v=ml0lG4sMTJU
.2013 Shelby GT500 Dyno Test - YouTube
Swamp Donkey Aficionado
Why's that? If these numbers were obtained all from the same dyno, I'd be inclined to agree with you; the results have come from at least two separate dynos (possibly three) and three different cars. For reference, Livernois ran an automatic 2012 Camaro ZL1 on their dyno and its numbers were 476 rwhp / 476 rwtq.
Ignoring the peaks (wonder if the wideband feedback is what causes the waviness of the curves), it looks like about 595 to the wheels, which is around 685 at the flywheel. No wonder they had to re-rate it at 662 HP - they were over the acceptable "tolerance" of the SAE rating.
Livernois for one has a reputation for overly optimistic dyno numbers a bit of a joke here in Michigan. The same dyno can vary from day to day let alone different dynos in different places. Who knows when the last time they were calibrated or even if the operators used the proper correction factors. I remember when the 5.0 came out they were tested in the wrong gear. The only number that is trust worthy is Fords crank number.
In regards to Ford's "trustworthy" crank numbers, just run that line by the folks who purchased 1999 SVT Cobras and see what kind of response you get...
Saw another video dyno test where the 2013 made 550+rwhp they stated with 12% drive line loss that's inline with the factory rating. They took it to Arizona and did 196mph at 200 feet elevation and very warm temperatures. They were sure it would do 200 if the straight were longer and the elevation lower.
This is the video. They got 583HP
2013 Ford Shelby GT500 Chases 200 MPH! - Ignition Episode 18 - YouTube
Yes that's the one. I couldn't remember exactly so I put 550+. And yes 2000 feet up. No matter what dyno reading is correct the car is amazing and that video really brings it home. Drive every day, do skid pad drives with little chassis oversteer, and do 200mph for less than $100k amazing.
