Exhaust
You start by using the search function menu displayed on the top of the page ![Lol](https://themustangsource.com/forums/images/smilies/lol.gif)
Received 1,528 Likes
they say an X-pipe will give a more raspy sound, in combination with straight-through "can" mufflers; might give you what you are looking for . . . I think I would start with that, before moving on to more expensive projects like headers
this is posted in the "Candy Apple Red" color sub-forum, you might get better response if you post in the general 2005-2010 forum . . . and scan the existing posts in that section or use the search feature to find the previous posts that talk about this
It all depends on whether running the stock exhaust or an aftermarket off-road/high-flow catted setup. If retaining the stock cats, an X crossover doesn't sound nearly as raspy when compared to running an off-road, mid-pipe setup. For my application, I run the "Pypes" cut n clamp X pipe to the stock cat down pipes with Borla ATAK axle backs. Other than just a slightly higher exhaust tone over an H-pipe, I don't really notice very much rasp at all. However, if running a high-flow catted or off-road X setup without adding mid-mounted resonators/mufflers? you'll more than likely encounter increased sound levels of rasp for sure lol.
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
m05fastbackGT (4/20/24)
Kevin! When I first stumbled upon that post, I honestly wasn't quite certain if it was spam or not... After checking the suspected spammer's birthdate as being prior to 1990, I figured that I would give the benefit of doubt by awaiting a response before banning them.... Meanwhile, thanks for confirming my suspicions by eliminating yet another spammer...
Sometimes You Just Gotta Wait & See!
KC
KC
Guess I just waited too long!
![Rollinglaugh](https://themustangsource.com/forums/images/smilies/rollinglaugh.gif)
mbreinin
3/25/12 04:27 AM
