Very Loud Knocking
Old May 15, 2008 | 07:47 AM
Mxyzptlk's Avatar
Very Loud Knocking
After a very aggressive driving session on the highway, I am now hearing a very loud knocking sound coming from my engine. I checked my oil and radiator fluid and it seems okay. Im sure I broke something but not sure where to check.
Old May 15, 2008 | 11:57 AM
theedge67's Avatar
Loud knocking is not a good noise and could be many different things. Does the knocking get louder when you give it more gas? Does it increase in speed with the engine, or with the vehicle speed? Did you notice any metal flakes in the oil on the dipstick?
Old May 15, 2008 | 03:13 PM
Mxyzptlk's Avatar
constant tick tick tick tick tick but loud. On all the time and increases in speed with the engine. No metal seen
Old May 15, 2008 | 03:15 PM
shaun_beauchamp's Avatar
Check the driver's side valve cover with the hood open and a "helper" on the gas pedal in neutral. If it is isolated to just the driver's side valves, I believe there is a TSB for 2005 Mustangs.
Old May 15, 2008 | 03:51 PM
Faber's Avatar
Could be an exhaust leak also.
Old May 15, 2008 | 04:53 PM
429 Boss Mustang's Avatar
ok so my bad this one sucks and the one below it no use
Old May 15, 2008 | 04:57 PM
this one sucked to
Old May 15, 2008 | 05:04 PM
jwooski's Avatar
check your spark plugs if you changed them one might not be improperly torqued min 18mn
Old May 15, 2008 | 08:36 PM
Faber's Avatar
Originally Posted by 429 Boss Mustang
and if your dont fix the problem bro its working on your cam and grinding it up cause if it is a rod your gonna have to pull that motor and drop tha pan and get da rod and get a new cam and rods . only if you slipped one
it what were doing to my sis chevy :/
This is an overhead cam motor. no pushrods at all. unless you are talking about a piston rod, in which case I am not sure how it would have anything to do with the cam. not trying to sound like a jerk or anything here just trying to help diagnose.
I would get a hold of a mechanic's stethoscope or a long dowel and put it to your ear and the other end on different spot on the motor. listen to the motor with it to try and determine where the knock is coming from. try to rule out exhaust leaks, a/c clutch issues, etc. if you hurt the motor badly I would think it would be pretty apparent.
did you hear anything out of the ordinary when you were on the throttle? how high did you take the RPM's?
does it make the sound when the motor is cold? also check for loose brackets, motor mounts etc.
Old May 15, 2008 | 08:39 PM
yea thanx bro i was wondering about that
thats why i said if in the first one
so if its overhead cam i dont know lol xD i been working on motors from 88 back so i really dont know what the inside of a over head cam looks like mind filling me in?
Old May 15, 2008 | 08:42 PM
Faber's Avatar
basically the lifters are just lash adjusters, and the cam sits above the valves and runs off a chain from the crank. the rockers roll from under the can and puch the valves down. I will see if i can dig up a pic.
Old May 15, 2008 | 08:46 PM
ok sweet i was wondering dude cause i work with my dad all da time on his 78 F 250 which i love gots a beast of a motor 460 cub
Old May 15, 2008 | 10:37 PM
jwooski's Avatar
also check for crank shaft end play put a pry bar between the lower crank pully and the timing cover see if the lower crank pully will move back & forth about 1/2 inch or so you
you may have excessive end play in the crank. also check your cam sensors one maybe slightly loose not making a good connection
Old May 16, 2008 | 07:28 AM
Mxyzptlk's Avatar
Was told by the dealer that it was a cam phase adjuster than needed replaced??? and told that labor was 5 hours and parts were about $500. This is above my knowledge level.
Old May 16, 2008 | 07:39 AM
jwooski's Avatar
cool be very carful on the crank end play replaced some cam phasers then go to find out the crank end play was excessive made that mistake before and no we didn't charge the customer for the phasers that was replaced gave that credit back to the customer
Old May 16, 2008 | 10:49 AM
Mxyzptlk's Avatar
Can you explain this issue to me -- I have never heard of phasers except on star trek.
Old May 16, 2008 | 11:42 AM
Faber's Avatar
Cam phasers are spring loaded sprockets that allow the Variable cam timing to change the cam angle.
Old May 18, 2008 | 06:14 AM
ford4v429's Avatar
legacy Tms Member
heres a exploded view of the head, and one of the whole engine...sorry for the text added to the engine pic- I was bored one night long ago while waiting for my ordered car...was going to print up a poster sized one for the garage wall, but never got around to it...the original pics are on this site somewhere(I think- if not it was the media.ford.com site)
Old May 18, 2008 | 06:22 AM
ford4v429's Avatar
legacy Tms Member
JWooski-
on the phase adjusters, what exactly goes wrong with them? is there a spool for the oil that gets stuck, bad solenoid, bad bearing on the sprocket, or what? I gotta ask as years down the road think we'll all be having to mess around in there...just wondered if theres any way to disassemble/loosen up what ever gets stuck type of thing...also gotta wonder if simply rocking the engine backwards a little with a breaker bar or such/any other thoughts that might help unstick one before it hammers permanently in the stuck position...thanks for any info
Old May 19, 2008 | 07:49 AM
If it sounds like this, you're in trouble.
