Trunk Sidewall
no issue with mine. If these are push-pin type, have you tried pushing them in farther? If screw-type, check the back-side clip.. perhaps it's the wrong size (to big) or too far back to grab screw/pin threads.
I've had the same problem with the screw on type of retainer onmy wife's 06 Convertible. The dealer has replaced them twice and both times they were loose before she got the car home. we had taillight wire issues, that have now been resolved. Anyway it's because the inside of the fastener has a very small lip that fits into the threads of the taillight screw and if it is forced at all when strating the lips will just strip right out. It's is a Ford part # W712314S300. At my local dealership the are usually is stock at @ 1.70 each. I just bought 4 as spares.
If your referring to the back piece of trim panel. Ford changed the fasteners mid 06 and the new style suck ***. It does not secure the panel tight. I had this problem and was able to locate some of the older styled screw type clips but ford no longer makes them which sucks.
TMDM
Sep 24, 2015 07:00 PM
