Squealing after driving thru puddle?
I have a 2007 Ford Mustang V6 convertible. I drove it through some big puddles on the road today and afterwards I had a squealing from engine. Loose belt? Bad belt? Any ideas/suggestions?
Yes. It went away.
Yes. Squealing went away. It happened to be right before where I needed to go. So I turned engine off a minute after it started. I was inside for about ten minutes. When I came out and restarted engine the squealing was gone.
Just about any car can have the squealing sound when running through some deeper puddles. The key is that it goes away shortly after starting. If it continues for minutes then I'd say there could be a bigger problem somewhere.
maybe already obvious from prior posts, just summarizing: the squealing is probably from a belt slipping because it is wet, and it should go away when it dries off, which should be pretty quick, usually only a few seconds
explorerst4x4
Mar 27, 2015 10:21 AM
1969 Boss429
Apr 8, 2011 03:24 PM
