Shifter Clutch linkage
Old Aug 30, 2022 | 04:41 PM
Jordancr1111's Avatar
Hoping someone here can help me with my 08 mustang gt. I need to replace the linkage between the clutch and shifter lever. The linkage is worn and slops around. Attached is a photo. You’ll notice the bushings are worn as well, never mind that they are ordered. What I need help with is the linkage name or part number, I can’t find it. Thank you for your help!
ignore the yellow circle.
Old Aug 30, 2022 | 05:14 PM
05stangkc's Avatar
That Bushing is Not Serviced Separately from Ford.
This Is a 2007 Vin I used so Part Number may not be Correct. The Aftermarket may have a Bushing Available.
https://www.fordpartsgiant.com/page_...&keywords=7210
This Shows the Different Levers By Production Date which is on your Door Jam if the Lever is What you Need! You Did not Say What Exactly Year And Model you Had But It Looked Like 2005-2009 Gt ???? And you are In the 05-09 Forum So I Dove in on Instinct.
https://www.fordpartsgiant.com/parts....html?pnc=7210
How About These!
Is This What you Need? Below Pic Red Bushings.
https://www.cjponyparts.com/prothane...All%20Products
Old Aug 31, 2022 | 04:36 PM
I have bushings, I need the linkage with the bot
Thanks 05stangkc
So youre getting close. I have the bushings I just need the linkage with the bot going through the top of it - its what the shift lever mounts to.
Im attaching another photo, ignore the red circle - can’t get rid of it, I need whats circle in blue. Thanks!
Old Aug 31, 2022 | 05:08 PM
05stangkc's Avatar
The Piece That Looks White Dead Center is Not What You Are After???
ElkGroveFordGuy
Mar 22, 2017 08:49 AM
blueroo64
Nov 1, 2007 08:19 AM
sonic98gt
Oct 31, 2007 01:09 PM
