Right turn signal in turbo mode!
Old 11/10/09, 01:48 PM
denlem's Avatar
Okay, i go to make a right turn today and my turn signal starts flashing/clicking at a speed that is 2-3 times faster than normal. After my turn I tried the left side and that flashed normal. Tried the right one again, still going fast.
Later on another right turn I turn it on again. Got a few flashes at what seemed to be normal, then it went fast again.
I'm not worried about warrenty or anything. Plenty of time left. Just curious if anyone has seen this happen and what it could be. I assume it's just a relay or whatever does the flashing, but you never know!
Old 11/10/09, 01:51 PM
You might have a bulb going bad. When I had a bulb go out on the rear it did this until I replaced it. Next time it does it, check and make sure the bulbs are actually flashing front and rear.
Old 11/10/09, 02:27 PM
I lust for a M24
05GT-O.C.D.'s Avatar
Yup, most likely wrong load being sensed by the flasher due to a bulb out.
Old 11/10/09, 02:34 PM
GONE_N_60's Avatar
The owners manual says that it starts blinking at a fast rate to alert you that a bulb is on its way out.
Old 11/10/09, 02:59 PM
codeman94's Avatar
This actually happened to me yesterday! Sure enough.... the right middle taillight wasnt flashing..I picked up a pair of 4057 on the way home from work today... and I'm looking on here for access to the tail lamps... I'l check Taco bills sequential how to
Old 11/10/09, 03:03 PM
codeman94's Avatar
https://themustangsource.com/showthread.php?t=438450
dang... way more involved that I thought. looks like you have to take the whole rear inner plastic off
Old 11/10/09, 03:25 PM
denlem's Avatar
Wow, good to know. I'm used to bulbs going out without a warning then the turn signal just staying ON when using it. I'll have to check and see if something isn't lighting up.
Old 11/10/09, 03:32 PM
denlem's Avatar
Just ventured out into the dark woods... Yup, there is a bulb out. The middle rear bulb works for the brakes, but is dark for the turn signal. 14K miles and a bulb gone already.
Old 11/10/09, 04:24 PM
Happened at 26k on my truck and 23k on the wife's Expedition. It always seems to be the flasher filament and not the brakes.
Old 11/11/09, 09:55 PM
legacy Tms Member
ford4v429's Avatar
umm, turn and brake should be the same filament- the other is the parking lamp.
check for wet carpet on the passenger footwell by the kickpanel, sure sounds like the smart junction box got wet from a cowl leak - heard a lot of times first indication was taillamps either not working or coming on just sitting there...usually just after rain/washing
Old 11/11/09, 10:34 PM
denlem's Avatar
Picked up my bulb today. A 2 pack cost me $5.49. Yikes! They were only 3 something at WalMart but they didn't have the right style.
Old 11/13/09, 04:49 AM
codeman94's Avatar
Changed mine out yesterday. Took me about 20 minutes. I little more involved that I expected it to be, but I bet I could do it in less than 10 mins next time.
Old 11/13/09, 05:34 AM
denlem's Avatar
I haven't done mine yet. Been a bit windy and chilly out, so i'm holding out for a bit of sun and warmth.
Old 11/13/09, 06:02 PM
legacy Tms Member
ford4v429's Avatar
I'd suggest checking it again before you change it- if it was due to wet SJB, it may 'fix itself' intermittently...just saying because I'm 99.999% sure the brake/turn are the same filament and the other is for the dimmer parking lamp- if so it still sounds like a SJB issue.
Old 11/13/09, 06:56 PM
nitecrawler27's Avatar
Yea the first time i changed mine it took about 20 min but now it takes less then 10. Sucks that you gotta take out the whole assembly just to change a bulb
Old 12/6/09, 04:17 PM
I-70 west's Avatar
I`ve got the CDC sequential and the turn signal and brake light is out on the rear left side but the front is fine.
The left side dash indicator is rapid fire still.
Old 12/6/09, 04:43 PM
I lust for a M24
Yeah, this sounds normal to me. Am I reading something wrong? Replace the left rear bulb that's out and things should go back to normal, right?
Old 12/6/09, 05:37 PM
I-70 west's Avatar
Yes, the inboard bulb was fried. changed it were good to go !
Old 5/27/10, 08:45 PM
07 GT/CS's Avatar
Resurrecting this thread, have the same issue on my passenger side. Swapped in a new front signal bulb and the outboard signal bulb in the rear. Still have the problem. I guess I should have taken a closer look at the middle bulb in the rear. Anybody know if it is the same 4057 bulb as the outboard light?
Old 5/27/10, 08:51 PM
I lust for a M24
all three in the bulbs in the rear lamps are the same from the factory, even the inboard ones.
Quick Reply: Right turn signal in turbo mode!
