Rear Window Defroster Problem?
Old Apr 4, 2014 | 09:26 AM
Ugabulldog83's Avatar
Folks, I have a 2005 GT Convertible and the wire clasp for the driver-side, rear window defroster came loose from the glass. Is this a common problem on the convertible? There have been 3-4 attempts to re-afix the metal clasp to the window glue-wise but they only held in a temp fashion. Is there by chance a TSB for this problem? Is there a successful method to re-attach the clasp used by anmyone on the forum? Thanks in advance for your help!
R/Mike
Old Apr 4, 2014 | 09:42 AM
southcarolina12's Avatar
R/Mike
here you go. you can buy it at most auto parts stores.
http://www.permatex.com/products-2/p...dhesive-detail
Old Apr 4, 2014 | 09:56 AM
Thanks, will try it, thought there might be a TSB on it. Seems the pressure from putting top up and down might be pulling the clasp off the window.
Old Apr 13, 2014 | 08:40 PM
Lime GT's Avatar
http://www.stangnet.com/images/stori...s/04-24-05.pdf
Old Apr 14, 2014 | 10:16 PM
JimC's Avatar
legacy Tms Member
It happened on my 2006 - first time the dealer fixed it the thing lasted a couple of months. I bought a kit from frostfighter.com and repaired it myself and it was still on there good and tight after another 100,000 miles.
ustabawannab
May 3, 2016 07:54 AM
rickey7575
Aug 21, 2015 11:40 PM
TonyJestis
Aug 21, 2015 06:06 PM
bob724
Aug 17, 2015 04:05 AM
lakersfreak
Aug 12, 2015 01:52 PM
