Problems loss of power
Old Jan 24, 2010 | 09:37 AM
Tungsten Bullitt's Avatar
Exclamation Problems loss of power
Hey my 07 v6 I've had a major loss of power. When I step on the gas the tac will increase to higher rpm's but I'm not getting the speed. Anyone know what this might be? I've cleaned my K&N filter.
Old Jan 24, 2010 | 12:24 PM
Greywolf's Avatar
clutch slipping?
Old Jan 24, 2010 | 12:36 PM
tom281's Avatar
Since the car is a manual trans, if you're saying that once you put it into a forward gear and push the acelerator, that the rpm's rise but there is no movement from the vehicle or the movement is greatly reduced, then I would agree with Greywolf regarding the clutch.
Old Jan 25, 2010 | 09:39 AM
Five Oh Brian's Avatar
How about plugged catalytic converters? That produces a constipated, plugged up feeling resulting in sluggish acceleration since the car can't expel exhaust easily.
Old Jan 25, 2010 | 09:45 AM
I don't think the rpm would climb if your cats were clogged. Or it would climb very slowly. Will your car still do a burn out?
Old Jan 25, 2010 | 07:54 PM
I have an off road x-pipe with no cats.....
Old Jan 25, 2010 | 07:55 PM
I haven't tried but I have noticed that the traction control hasn't been going on much like it usually does when I take off....
Old Jan 25, 2010 | 09:02 PM
Has anyone had to have theirs replaced? If so what does it run from the dealer?
Old Jan 27, 2010 | 06:15 AM
a dealership will cost you a lot more than a local shop in most cases. Its a pretty straight forward job so you might want to shop around. Just guessing but I would think a dealership would be around 1000.00
Old Jan 28, 2010 | 03:04 AM
DynamicmustangGT's Avatar
Ford wants around 1000 just for the labor, a private shop would be around 550 plus the clutch.
Old Feb 1, 2010 | 07:05 PM
Yeah it's the clutch. I only have 38K on her. Ouch!!!
Old Feb 1, 2010 | 07:12 PM
60k drive train warranty?
Old Feb 2, 2010 | 04:33 PM
06GT's Avatar
Here's a "free" check, pull your MAF and clean it. I've heard some horror stories of ****ty performance from MAFs that have K&N filter oil on the MAF sensor element.
The car might think the wrong amount of air is entering the engine, causing poor performance vs. RPM.
Did you thoroughly dry your filter after cleaning?
Road_Runner
Sep 2, 2024 04:46 PM
Rando
Aug 25, 2021 11:12 AM
RCooke08GT
Feb 19, 2017 03:03 AM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
