Out of warranty what have you had to replace
Just a turn signal bulb here. I will be needing brake pads soon but thats regular maintenance. So what have you had to replace out of warranty and how many miles were on your car at that time. I'm thinking this will be a short thread.
Tires at 45K due to the lefts being slashed. Punks. A couple of rear turn signal bulbs here myself, less than 45K miles. Brakes are coming up too, and we're at... uh... 52k I think now. So far, that's it, other than the standard oil change and such.
Nothing major - guess I should expect something in the 70k mile range though. I've been told I can still get a warranty plan but so far its still been a good car.
1) Taillight seal leaked water into trunk - around 40k miles
2) Throttle Body replaced - needed more than a cleaning, car would stall while on the freeway, RPM spike - btwn 40-50k miles
3) Freaking driver's seat switch failed, this annoyed me the most, its an expensive lil switch - 62k miles
My big expense was the leak in the passenger side foot well , which I didn't discover it till after the car was out of warranty. First try cost me $610 and the second one they said they would split the cost with me and I paid $266. That was last year and month or so ago we got a lot of rain and guess what , it's still not fixed. I currently have about 67K miles on the car and will have had it for 6 years in November and other than that I haven't had any real problems , except ones related to all the modifications I've done ...
Jim you bought a warranty nothing will go wrong with your car untill that ends! At least thats how those things werk for me. lol
I still have 2 years or 40 000km to go though.
Nothing yet as my warranty expires on Saturday... but I do have 2 open items that are covered, but waiting for the parts to arrive (new top and Shaker 500).
I had to replace the 3rd brake light bulb
The rear passenger side brake hung up and went down to metal. I did a brake job all the way around at 60-65K when that happened.
I have a rattle coming from under the car when its cold...its from an accident I had almost 2 yrs ago.
32K here... Oil and filters, a cracked intake manifold covered under warranty, exhuast hangers removed per TSB under warranty and a rear sidemarker bulb.
Just had to have my throttle body replaced today on my 2006 GT as well as the rear brake pads. My car has 38,000 miles on it (I work close to home and alot so I don't get out much! ). hmmm mileage warranty 36,000 miles, issues at 38k. Coincidence?
Out of Warranty 05 GT man trans
Now I'm working on all the things that were wrong under warranty and the Stealerships did not get fixed properly.
If I had to do it again, with a car under warranty, I'd keep going back over and over until they fixed all the problems.
1, Lumbar: Fixed under warranty lasted about a year, broken again.
2. Outside door handles won't retract: They adjusted linkage rod clip, now I know the real problem...both handles have broken plastic inside..up to me now.
3. Dash vents don't always work: Don't know if it is an intermittant actuator motor or just binding of the vents in the housing itself.
4. Play in steering: three dealers could not find the problem. I found it after warranty expired...the shaft between steering wheel and rack has play inside the collapsible part of shaft. Part $300. when I have the money.
5. Rattle right end of dash...they never found it
6. Rear brake rotors warped...due to frozen cables... they replaced cables but did not fix the rotors.
Numerous other problems which were fixed under warranty, by the THIRD dealership I took the car to. Not very fond of Ford Dealerships. They make you beg them to do the work. Then only agree to do the work IF you agree to NOT take a loaner car. Then they say "no problem found" or "unable to verify complaint" even when I take them my copies of TSBs I have downloaded from the internet which relate EXACTLY to the problem I describe.
A Nice car with no major problems so far, yet too many minor problems due to either poor quality of parts or early designs of those specific parts.
Never buy an American car until at least the second, or better yet, the third year of a new bodystyle.
I like the car. I will never love this car.
50k miles on it so far.
I am a retired 63 yo former Honda car tech. Now I fix my Mustang stuff by myself...as warranty is expired. Had great fun fixing water leaks on the above car last summer. Now I know all about them. Mine were caused by a microburst storm which damaged the window weatherstrip retainer tape...so not Ford's fault. But now I have read and understand all the TSBs about water leaks in these cars.
Money is tight for me now. Some things will have to wait.
Can't wait till I have $ to fix the steering which has annoyed me more than anything else since I purchased this car.
I also had an 05 V-6 Coupe Auto. That car was built withing two weeks of this car in the same factory and had ZERO problems. Go figure ! It is the luck of the draw literally...having to do with the parts that go into these cars. Neither car had major trans or engine issues...so it is not the difference between a GT and a V-6 components. It is the luck of all the other little parts that went into these cars...or the day of the week they were built ?? LOL.
My dealer is terrible. They ignore TSBs and you have beg them to fix anything; I'll never buy from them again.
Btw, see if you have an A-arm brace installed. If not, get one. It will cut down on internal noise (rattles) and keep the car more stable. You'll feel and hear the difference.
Founding MOTM
Committee Member
Committee Member
Under warranty:
Aux port
Fog light lenses(they cracked)
Reattach driver side scoop.
Reinsert headliner on driver side
Rear brake pads/rotors/driver side caliper for sticking
Not covered under warranty over the life of the vehicle:
Valve stems(cracked)
Battery
Tires at 50k(due to blowout, figured just get a new set)
My Shaker500 took a crap and won't play CD's anymore, but since my dealer apparently can't/won't give me a rental until 24 hours AFTER they've had my car(when they won't even need it that long) and I absolutely need a vehicle at all times, I said screw it and just use my iPod 24/7 now.
Now that i'm making this list, i'm starting to think my CS has something against me. A bunch of that stuff is driver side.
Aux port
Battery
under warranty....
1 battery
1 set tires (at 25000 miles)
1 fuel tank (TSB for refilling and after replacement, caused my exhaust to rattle)
1 Shaker 500 radio (TSB)
Out of Warranty...
1 battery (Replaced with Optima battery after same failure as the 1st battery)
Water leak around 3rd brake light into trunk
various bulbs
Vinal inserts on BOTH door panels (vinal peeled off the doors the day after the 45th Anniversery show in Birmingham
Both Cam Shaft Sensors
and NOW a rear pinion seal that they missed after a (In)complete Multi Point Inspection Service (Possibly more than one judging by the amount of lube on the bottom of the car)
1 battery
Out of Warranty...
various bulbs
