Noise when turning in parking lots,etc
Every time I turn in a parking lot or similar places my car makes a very loud squeaking noise. This doesn't happen with I'm driving on the road or anything, just when I maneuver through parking lots. Really embarrassing. I thought it was my tires, that maybe they were low, but I checked them and they have 45 psi, at 50 max so that's not it....any ideas? Also it isn't the squeaky belt, as I've had it before and it's not like that. More like something bending...or stretching.
Originally Posted by POS VETT
How wide is your front tire ?
NITTO Extreme Performance NT555 Mustang Tire 255/45-18
These on the back
NITTO Extreme Performance NT555 Mustang Tire 275/40-18
Also my T-lok is less than a year old...it's a ford racing t-lok.
Sqealing when the steering wheel is all the way to the lock? If so it's normal unless its really loud.
Could be the tires. Some make more noise than others.
Is it on blacktop only or all surfaces?
Originally Posted by 825LTRGT
Good point. It could be the tires rubbing on the fender wells.
Do you still have your stock rims/tires? If so, put 'em on and see if it still makes the racket.
I recommend you bring your vehicle in to your Ford dealer for diagnosis. Your Service Manager is in the best position to look into this for you. He can look into any warranty, Recalls, or Customer Satisfaction Programs that may apply to your vehicle. If you need further assistance, do not hesitate to PM me.
Deysha
Look for rub marks on the fender liners. If it's rubbing there will be marks.
I'm no PS expert but the PS pump has a pressure relief when the wheel is turned all of the way, I think. The PS pump puts out a lot of pressure. Around 1500 PSI and it has to go somewhere or the pump would not survive.
Is the PS fluid dark?
I made a video of the noise, It's at about 13 seconds in. Please check it out and let me know what you think it is..
http://youtu.be/9KP-VOPZvWQ
