New TSB for Rear End?
At greenway ford in Orlando to day for the rear end noise,5th time.They say that a new TSB will be out for a fix??They say it works this time so in 7 to 10 days i will let yous know.??????
As of this morning this was the complete list according to OASIS:
Technical Service Bulletins
2006 MUSTANG - US (English)
06-4-2
BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
06-4-1
RATTLE/NOISE FROM THE CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA
06-3-13
FUEL FILL SLOW, OR DIFFICULT TO FILL
06-2-9
DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V
06-1-5
DTC P1000 MAY NOT CLEAR IN HIGH ALTITUDE CONDITIONS
05-24-6
CONVERTIBLE SYSTEM CONCERNS
05-22-8
WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING
05-20-2
REAR AXLE NOISE
05-18-7
WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-16-12
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
05-9-3
INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
________________
TSBs found:11
Here is the list for the 2005's:
2005 MUSTANG - US (English)
06-4-9
A/C COMPRESSOR NOT OPERATIONAL / LOW FREON - SHAFT SEAL LEAKS
06-4-7
TICKING AND/OR KNOCKING NOISE FROM ENGINE - 4.6L/5.4L 3V
06-4-2
06-4-1
06-3-13
06-2-9
05-25-15
MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V
05-24-6
05-22-8
05-21-2
LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS
05-20-2
REAR AXLE NOISE
05-19-10
LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT
05-18-10
BRAKE NOISE - VEHICLES BUILT BEFORE 3/8/2005
05-18-7
05-16-12
05-15-13
FRONT SIDE MARKER LAMP RETAINING TAB BREAKING
05-15-12
FUEL FILL SLOW, OR DIFFICULT TO FILL - VEHICLES BUILT BEFORE 4/26/2005
05-15-2
GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 2/21/2005
05-14-4
WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-10-19
INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
05-9-14
CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-11
FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
05-9-3
05-8-6
EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-7-3
AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
05-6-15
AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
05-3-1
MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-22
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-26-16
WELD BONDING PROCEDURE
04-24-14
GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-9-6
BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
________________
TSBs found:32
06-4-2
06-4-1
06-3-13
06-2-9
06-1-5
05-24-6
05-22-8
05-20-2
REAR AXLE NOISE
05-18-7
05-16-12
05-9-3
________________
TSBs found:11
06-4-9
06-4-7
06-4-2
06-4-1
06-3-13
06-2-9
05-25-15
05-24-6
05-22-8
05-21-2
05-20-2
REAR AXLE NOISE
05-19-10
05-18-10
05-18-7
05-16-12
05-15-13
05-15-12
05-15-2
05-14-4
05-10-19
05-9-14
05-9-11
05-9-3
05-8-6
05-7-3
05-6-15
05-3-1
04-26-22
04-26-16
04-24-14
04-24-5
04-9-6
________________
TSBs found:32
robjh22
9/8/15 12:31 PM
