NEED HELP MY '07 GT/CS GOT HIT
Old Oct 28, 2009 | 07:12 AM
pilatti1's Avatar
Some dumb minivan driving woman Backed into the driversdie front 1/4 panel on Monday , There is a small dent (very small) right above the GT/CS stripe but it then pushed out above at the very top of th the fender well. A body shop thinks Dent Wizard could fix both issues which then there would be no painting required, any thoughts? Another body shop wanted top replace the 1/4 panel paint the panel & blend the hood & door, so i am confused on which route to take. HELP!!
Old Oct 28, 2009 | 07:16 AM
First Stang's Avatar
I hear the magic dent repairs are pretty good and then you don't have to worry about paint blending/matching.
Old Oct 28, 2009 | 07:23 AM
825LTRGT's Avatar
If the panel isn't creased or the paint isn't crack, chipped, or too messed up, the Dent Wizard should be fine.
Old Oct 28, 2009 | 03:05 PM
karman's Avatar
If the Wizard can't do it, you can always go the conventional route.
Try the Wizard first. Do they guarantee their work?
Old Oct 28, 2009 | 06:00 PM
stang7300's Avatar
To echo what others have said and...
If you get a good dent guy, they'll tell you if they can do it right or not. When I had my '06 GT, the dent guy told me he wouldn't be able to do a proper job since it was creased. I don't believe it was a lack of skill on his part, but pure honesty.
Good luck either way you choose.
Old Nov 3, 2009 | 10:52 PM
GONE_N_60's Avatar
I knew a few good PDR guys. If its not on a body line i.e. angle or crease, then PDR should work, but if it's in an oddball space or complex angle, even the best PDR professional knows not to play with it and make it worse.
Fords4Ever
2011 - 2014 GT/CS
21
Mar 1, 2021 12:22 PM
Gill5oh
Oct 6, 2017 10:50 PM
NC14GT
Sep 10, 2017 04:47 PM
tbear853
Sep 8, 2015 11:18 PM
