Loud Backfire!!!
Loud Backfire!!!
Today I tried to get rubber when shifting into 2nd and instead of a tire squeel I got a very loud backfire. I had the RPM's up high but not near the red line and as soon as I shifted into 2nd is when it backfired. What could have caused this to happen? Should I be concerened as it is a stock '07 GT/CS?
I bought cheap gas at BJ's and I believe that may have been part of the issue. With a 1/2 tank I filled the rest with Exxon 93 Octane and the problem is not there and my MPG's went from 13 to 21.
Thanks for the input
Did it happen after you let the clutch out in second ? Because if it was that, maybe your traction control kicked in and did something to the spark sequence because of the quick lack of traction . Try it again without the traction control being on .
Mine will back fire on wet roads when the traction control kicks in while accelerating hard.
Rando
Aug 25, 2021 11:12 AM
Rando
Sep 30, 2015 12:28 PM
