05 gt won't start
Old Mar 17, 2008 | 11:48 AM
k-rash's Avatar
05 gt won't start
car cranks just like normal, no funny noises, has fuel pressure.(* i assume because the fuel pump kicks on)
but the car wont start. my dummy light for the theft security blinks when I crank the car..
any ideas????
I'm pretty sure that I'm the second owner of the car and it only has 31,015 miles and was built in 04/05
So would this be covered by warranty?
Old Mar 17, 2008 | 12:41 PM
theedge67's Avatar
The warranty starts the day the car is sold, not built. Either way, it will still be under warranty because it has not been 3 years since it was built. Check the owners manual, there was some info on the anti-theft system and that light blinking. I can't remember what it meant though right now.
Old Mar 17, 2008 | 12:56 PM
reset/push your fuel cut off switch any way.
Old Mar 17, 2008 | 01:45 PM
k-rash's Avatar
im assuming this is in the trunk like every other mustang?
Old Mar 17, 2008 | 02:00 PM
Clark Kent's Avatar
no its actually on the left side in the footwell , on the drivers side. There is a little indent there and the switch is inside.
Old Mar 17, 2008 | 02:04 PM
k-rash's Avatar
good thing i asked.. haha
Im much more accustomed to my 91 where the inertia switch is in the trunk.
Old Mar 17, 2008 | 07:10 PM
k-rash's Avatar
but that didnt fix it.
car is sittin at the dealership and is suppose to get worked on/looked at tomorrow first thing
Old Mar 17, 2008 | 07:34 PM
let us know
Old Mar 17, 2008 | 07:37 PM
n8rfastback's Avatar
hmm interesting... i wanna know whats wrong with it too
Old Mar 18, 2008 | 07:20 AM
k-rash's Avatar
sure thing.. hopefully they re calibrate my window too... since it somehow does the stay all the way up, or just a little ways down.
man, i miss my stang already.. haha now i have to drive a taurus...
Old Mar 18, 2008 | 02:39 PM
k-rash's Avatar
well they said its not bringing up ANY codes in the computer other then an out of range temperature for the coolant.
although the car does have good fuel pressure.
but they said this wouldnt cause it not to start.
I guess the plugs in the car were completely carbon'd over with only 31015 miles on it
they broke off spark plugs in both heads, but i guess all the plugs that came out were cracked, and carbon'd up
so that seems to be the problem ( or so they like to think it is)
Old Mar 18, 2008 | 03:46 PM
hmmm
arent our plugs supposed to be good till 100k??
if not, i may have mine changed out at like 30k or so, so they dont break them off later on
Old Mar 18, 2008 | 04:52 PM
k-rash's Avatar
Originally Posted by n8rfastback
hmmm
i thought they were good for a ridiculous amount of time..
but.. still at 30k they are carbon'd up enough for the car not to run.. ?!? hell i dunno
Old Mar 18, 2008 | 04:56 PM
I pretty sure they say to change them before 30k
Old Mar 18, 2008 | 05:13 PM
i dont think so...
i think they are SUPPOSED to be good till 100k.
anyone else know?
maybe its time to get out the manual
Old Mar 18, 2008 | 06:46 PM
theedge67's Avatar
100K change interval. I was thinking about having mine changed soon, I even bought some new plugs in anticipation. Now I'm thinking I might wait it out, since I have 60K miles on them already. I'm thinking that I have a really good chance of the dealer breaking at least one plug, and they flat out told me that I would be paying labor on whatever they had to do to remove the broken plugs.
I'm having no issues with the plugs so far, everything is great...I might wait until 100K and then have them changed. At least then I can say I did exactly what was in the manual.
Old Mar 18, 2008 | 08:00 PM
if you do whats in the manual and they break them, isnt it their fault???
you should not have to pay for broken plugs installed by ford and serviced by ford within the correct service interval
Old Mar 18, 2008 | 08:11 PM
theedge67's Avatar
That's what I think too. I can only hope that I can find a dealer that thinks the same way as me.
Old Mar 18, 2008 | 08:29 PM
SD CALSPCL's Avatar
TSB for Spark Plugs
There is a Ford TSB 08-1-9 for removing the plugs. The dealer should know this and follow the procedure. If he breaks them, he buys them.
See this thread:
http://forums.bradbarnett.net/showth...ht=Spark+plugs
Hope this is helpful
Old Mar 26, 2008 | 09:41 PM
k-rash's Avatar
well i got my car back.. FINALLY
ended up they
just busted the rest of the porceilin out of the plugs, then tapped them with a left hand tap, and backed them out. put new ones in. and that fixed it
same technique used on the 5.4l motors
