Hit a curb, axle housing & shaft replaced, but...
Old Feb 5, 2008 | 12:03 PM
RobRob's Avatar
I took it home from the shop (Driver's Edge near Dallas) and have noticed a ringing-like whine from the rear right side (where original problem was) when I accelerate at speeds above about 50 mph. Maintaining highway speeds require slight accelerations and it's most noticeable then. The sound goes away if I let the car coast. This was much more pronounced the first time I took the car home from the shop (after they replaced the bent axle), whereupon they said the housing was bent, too. So I had it replaced, and now the sound is much less noticeable, but still there nonetheless.
I looked on the list of stuff they did to the car and noticed that the only non-OEM parts they used were for the rear axle bearing, differential sealant and differential lube.
It sounds like bearings, but then, I don't know much about that stuff -- which is TERRIBLY FRUSTRATING.
Any thoughts or suggestions would be appreciated.
Old Feb 10, 2008 | 10:33 AM
frdtch05gt's Avatar
Sounds likely to be the carrier bearings that are making noise. If the ring and pinion weren't set up correctly in the new housing, that would cause bearing noises. I would bring it back to the shop that did the work and have them make it right.
Detroit Steel
Sep 21, 2015 03:35 PM
mustangsally_
Sep 18, 2015 05:35 AM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
