Help! Turn Signal Problem
When you say the signal lights up, do you mean the dash indicator or the actual exterior signal bulb? If it is the dash indicator, check all of the bulbs outside the car as this is the way the car indicates you've got a bad turn signal bulb.
Sep 8, 2015 10:45 AM
