Have the non-retracting exterior door handles been improved?
Old Jan 1, 2007 | 11:33 PM
Giddyup's Avatar
I had to get my drivers side replaced last year, and now my passenger side has done the same thing. I think this is a plastic pin that breaks inside the handle, but does anybody know if they have improved the quality of these handles, or are they the same stock? Just curious, because if they are gonna keep breaking, I will be inclined to just live with it......
Old Jan 2, 2007 | 01:19 PM
06SilverBulet's Avatar
I had my driver door handle replaced 3 weeks ago, since it was sticking. I honestly doubt that its better quality or will last a long time. Just have to be gentle with the car.
Old Jan 3, 2007 | 12:15 AM
Giddyup's Avatar
Yeah, I think I am going to have them order me a new handle for the passenger side.
Old Jan 3, 2007 | 01:26 AM
samckernan's Avatar
I figured my handle was just sticking. You're saying that some plastic part is breaking in the handle mechanism? Please elaborate. Thanks man.
Old Jan 3, 2007 | 06:30 AM
lodom's Avatar
I thought someone posted a fix for it sometime back. I haven't searched for it. It had detailed instructions on how to mod the handle so it won't fail to retract again.
Old Jan 3, 2007 | 07:50 AM
Dineau's Avatar
You are right there was a post on how to fix this and prevent it from happening again but I can't find it..
Old Jan 3, 2007 | 08:35 AM
jjcastle's Avatar
The dealer replaced my driver side door handle on my 2007 before I even picked the car up. I think it had that same problem.
Old Jan 3, 2007 | 10:33 AM
metroplex's Avatar
Fire mission: Let's find that thread on how to permanently fix the door handles!!!
Old Jan 3, 2007 | 11:00 AM
Sniper415's Avatar
When I first got my car, one of the first things I noticed is how the handle didn't seem to be able to handle the weight of the door. Since then I pull on the handle to unlock the door and then pull the door open using the edge of the door. This is poor design, but hopefully, I won't have any problems.
Old Jan 3, 2007 | 04:11 PM
BigWorm2005GT's Avatar
Easy fix: Take it to the dealership and let them fix it. It is a known TSB (can't recollect the TSB #) but it was taken care of in three hours in my case.
Old Jan 3, 2007 | 05:08 PM
Ranger's Avatar
If anyone does have the TSB # - would be good to have. When this problem came up as a thread, I checked the TSB listing on this site and also MyCarStats and couldn't find it.
Old Jan 18, 2007 | 03:03 PM
GATORBAIT9696's Avatar
Same issue here
Old Jan 18, 2007 | 08:58 PM
Boltzman's Avatar
Had mine replaced on passenger side..they come prepainted.The guy had mine installed in 30 min.I had to make 2 visits though.One to diagnose and the second one after it was delivered to them
Old Jan 19, 2007 | 01:11 AM
Giddyup's Avatar
They told me at the dealership that there is a plastic pin that has been breaking inside the handle. Can't elaborate any more than that, because I don't have a clue other than what they told me, but having had the drivers side done quite some time ago, now I need to do the passenger side.
Old Jan 19, 2007 | 09:45 AM
Dineau's Avatar
I'm still surprised that they replace the full outside handle for this probleme. because what I saw in previous thread about this issue it's in connection of the rod to the macanism that is slipping when it happens. It has nothing to do with the actual handle itself.
Based on older threads that I have read, it,s a plstic threaded clip that is slipping on a threaded metal rod, that is slipping out of place and changing the adjusment of the handle. The solution was to add a metal nut on the threaded rod before and after the plastic clip to lock it into place so it won't slip.
Why changing the whole door handle ?
Old Jan 19, 2007 | 06:17 PM
Giddyup's Avatar
Evidently most Ford service depts. don't realize this fix (if it is fact), but it would be nice to know for sure, to be able to print this info out for all of our respective dealerships to have on hand, since obviously alot of us will be having this problem addressed.
Old Jan 21, 2007 | 06:18 PM
Legacy Tms Member
Nope, the fix doesn't always work - the dealer replaced our passenger side when it was 3 months old, then wanted to do the "fix" on the driver's side 3 months later when it broke.
Long story short, I ended up getting a new driver's side as well... so much for the "fix"
Old Jan 22, 2007 | 12:02 PM
Giddyup's Avatar
Thanks Marcello...... Knowing your experience on the matter, I will not even bring the 'Fix' to their attention , and just have them order the whole new handle for the passenger side instead.
Old Jan 22, 2007 | 10:45 PM
Legacy Tms Member
Well, I will say that when the free time presents itself, I have a fix in mind that will be more permanent than just replacing it with another OEM ready-to-break handle.
Old Jan 23, 2007 | 05:48 AM
metroplex's Avatar
Door poppers?
