Grooves in Brake Rotor
Old Feb 23, 2014 | 01:52 PM
Pony07's Avatar
Hey guys,
I had my brakes done less than 2,000 miles ago. The rotors were professionally resurfaced and looked like new when I drove out. Some time later, the right front took on this appearance. The left still looks even. I can't tell any difference in the brake action, I don't think. What would cause this? There's like grooves around it - it looks really weird how the outer edge is very clean.... or shiny (glazed). Was it from debris getting on the wheel? Or a bad cutting job?
I've only done local driving since the brake job, much of it on the highway about 20 miles or less at a time. No extreme heat - its been kind of cold. These are factory rotors with 92,000 on them, and they did not look like this before I had the brake job! I don't know if I should do anything about it.
Old Feb 23, 2014 | 03:16 PM
Both rotors should look nice and smooth. I wonder if that caliper is hanging up a bit?
Old Feb 23, 2014 | 05:54 PM
Pony07's Avatar
How would I know? I assume it would pull to the right while braking?
Old Feb 23, 2014 | 07:15 PM
PJRManagement's Avatar
Currently a Corvette Owner!
You can go back to the repair shop you had this done at to see what they say. I have a feeling they may tell you that un-even wear can happen at times, and that after several hundred miles more driving the pad will even itself out with the rotor, and establish a smoother surface. I'm not saying that is the best answer, but probably what they will tell you.
boz
Oct 1, 2015 04:47 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 16, 2015 06:44 PM
