Fuel pump covered under powertrain?
My car basically died while cruising on 95 and threw a low fuel pressure code from the fuel rail sensor. I haven't gotten it to die since. I've still got a little more than 1000 miles left of my powertrain factory warranty and IF it's the fuel pump I was curious as to whether or not it's covered. does anyone know?
Here is what is covered under your Powertrain Warranty. You should still speak to the Service Manager at your Ford dealer about this. They are in the best position to look into this for you.
Deysha
I was just thinking about my fuel pump(s) the other day. If you happen to have them replaced, could you post how much it cost and if you replaced both of them at the same time.
9/16/15 06:44 PM
