Fuel Problems
Old Mar 19, 2014 | 05:05 PM
Dermad23's Avatar
Post Fuel Problems
I have a 2006 GT that recently started having fuel issues. The fuel gauge goes to one extreme to the other when I get to 1/2 a tank. Within a few second it will jump between empty and 1/2 a tank. I thought it might have been the stepper motors, so I hooked up a Aeroforce Gauge to monitor how much fuel was left. Well today I supposedly ran out even though I know there was at least five gallons left in the tank. The Aeroforce Gauge said I had 30% fuel remaining while the Fuel Gauge said I was empty. My question is does the Fuel Gauge control the computer and tell the engine to shut off even though there is fuel still left in the tank? I have since filled up the tank and it only let me put around 10 gallons in it and now the Fuel Gauge and the Aeroforce Gauge say the tank is completely full.
Old Apr 12, 2014 | 07:42 PM
GottaHaveIt's Avatar
If you know how to remove fuel pump on drivers side under rear seat & a sending unit on passenger side to clean up & inspect it may help ?
http://fastoemparts.com/parts/2007/F...iagram=JC05800
Old Apr 12, 2014 | 10:19 PM
Lime GT's Avatar
https://themustangsource.com/galaxie...sb06_10_13.pdf Try doing some research on the tsb. I believe some were using Techron, a fuel additive that would clean sulfur from the sender.
http://www.stangnet.com/images/stori...s/08-04-17.pdf
http://caddyinfo.ipbhost.com/index.php?showtopic=18492
Old Apr 13, 2014 | 01:10 PM
I tried techron kinda fixed it for maybe a month then when i got to 1/4 tank it started bucking bad, I read more then went fuel pump, now you likely don't have to buy a pump just a seal about 18.00 pull out pump clean up the pick up put back and SHAZAM IT'll go like stink
Old Sep 5, 2014 | 09:34 AM
05GT4.6's Avatar
Where did you get this seal?
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
