Driver side leak
Old Jun 19, 2019 | 08:24 AM
matt2019's Avatar
Driver side leak
I have a 2006 mustang GT and water leaks from firewall when it rains, I have removed the drain hole grommets and seam sealed every thing I can reach and replaced cowl clips and sealed them. I slowed down the leak but can't figure out how to stop it, I've tried a smoke machine and I don't see any smoke in the area. Has anyone else had this issue? Where did you find the leak? My floor is rusting, I need this fixed asap! Thanks
Old Jun 20, 2019 | 12:02 PM
05YellowGT's Avatar
I had to have both my fenders pulled and have the seams sealed.
Old Jun 20, 2019 | 01:12 PM
matt2019's Avatar
I guess I'll be taking my fender off, can't hurt to reseal it.
Old Jun 24, 2019 | 05:17 AM
05YellowGT's Avatar
Mine was leaking on the passenger side, it was at the seam so I knew needed to be sealed and it did fixed it. I also did the driver side, even though I don't think it was leaking, but as you can see it was probably just a matter of time.
Old Jun 24, 2019 | 02:44 PM
matt2019's Avatar
I think I got the leak fixed I took carpet out only to find the passenger side has been leaking apparently for a long time there was standing water in the floor, the top of carpet was dry and car never smelled musty and damp but the floor is rusted and I have to find the leak all over again😫.
Old Jun 25, 2019 | 01:32 PM
hobojack's Avatar
Did you seal around the harness that goes through the firewall on the passenger side? That was I believe a recall or TBS
Old Jun 25, 2019 | 02:39 PM
matt2019's Avatar
I have not sealed around harness, I was scraping rust off floor pan and popped off a plug in the front left of passenger side. I ran water over windshield to see where leak is coming from and saw water running like a river under the plug. Why would water run under floor pan? It does it on both sides of car like it was designed with a channel under floor.
rhrh
Dec 8, 2015 03:57 PM
hsobuck
Jan 14, 2015 01:01 PM
*MustangTherapy*
Apr 18, 2013 08:10 PM
mptant913
Aug 24, 2011 05:26 AM
metroplex
May 7, 2008 08:27 PM
