Drains in cowl
Old Dec 2, 2024 | 06:35 PM
mlan12's Avatar
Drains in cowl
I have seen the drains in the engine cowl being removed and not replaced to solve the problem of them being plugged with debris. Is it ok to not replace these drains?
Old Dec 2, 2024 | 07:09 PM
05stangkc's Avatar
Welcome,
I Think That is a Matter of Opinion And You Would Get Varied Answers. Might As Well Just get Used To Checking The Cowl Everytime The Cabin Filter is Replaced. BTMO
Here is the TSB and a Vid For You To Watch And Make Your Own Call. Other Related Threads in the Repair & Service Section Sticky Threads as Well!
https://themustangsource.com/forums/...26-7-a-550617/
KC
The Wiper Motor Can Be an Issue as Well!
https://themustangsource.com/forums/...4/#post7088274
Old Dec 3, 2024 | 11:47 AM
m05fastbackGT's Avatar
I always check the drain plugs for any debris and then just put them back in, as they're really easy to remove and reinstall... In my honest opinion, if your car is exposed enough to accumulate dirt and debris for prolonged periods of time, I wouldn't trust in just removing the drain plugs as a 100% guarantee in preventing the drains from plugging up... Therefore, I strongly suggest once again to always check the drain plugs every 3-6 months to make certain the drains are not getting obstructed with dirt and debris...
sarnold58
Jun 9, 2019 02:22 PM
oldnjguy
Aug 5, 2018 07:23 AM
jato
Mar 23, 2014 06:23 AM
tang65c
Jul 15, 2011 07:30 AM
slipnotovk
Jun 13, 2010 12:28 PM
