Does anyone has the list of error codes for the mustangs 2005 and up?
Old Feb 2, 2007 | 09:03 PM
PATAN's Avatar
All Trouble Codes! Including Body Codes! FORD SPECIFIC!
https://themustangsource.com/forums/...e-info-550470/
KC
Admin 01/09/24
Hi Guys, I just installed the bama tune race 93 on my 07, and the check engine went on, I checked error p0171 and p0174 I think.
I re installed the tune and the errors are gone, but I am a little concerned, I can't find anywhere the error code list.
Thanks For the help!
Old Feb 2, 2007 | 09:29 PM
GrabberPony.com's Avatar
Fuel and Air Metering
· P0100 Mass or Volume Air Flow Circuit Malfunction
· P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
· P0102 Mass or Volume Air Flow Circuit Low Input
· P0103 Mass or Volume Air Flow Circuit High Input
· P0104 Mass or Volume Air Flow Circuit Intermittent
· P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
· P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
· P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
· P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
· P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
· P0109 Intake Air Temperature Circuit Malfunction
· P0111 Intake Air Temperature Circuit Range/Performance Problem
· P0112 Intake Air Temperature Circuit Low Input
· P0113 Intake Air Temperature Circuit High Input
· P0114 Intake Air Temperature Circuit Intermittent
· P0115 Engine Coolant Temperature Circuit Malfunction
· P0116 Engine Coolant Temperature Circuit Range/Performance Problem
· P0117 Engine Coolant Temperature Circuit Low Input
· P0118 Engine Coolant Temperature Circuit High Input
· P0119 Engine Coolant Temperature Circuit Intermittent
· P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
· P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
· P0122 Throttle/Petal Position Sensor/Switch A Circuit Low Input
· P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
· P0124 Throttle/Petal Position Sensor/Switch A Circuit Intermittent
· P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
· P0126 Insufficient Coolant Temperature for Stable Operation
· P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
· P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
· P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
· P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
· P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
· P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
· P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
· P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
· P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
· P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
· P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
· P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
· P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
· P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
· P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
· P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
· P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
· P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
· P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
· P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
· P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
· P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
· P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
· P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
· P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
· P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
· P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
· P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
· P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
· P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
· P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
· P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
· P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
· P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
· P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
· P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
· P0170 Fuel Trim Malfunction (Bank 1)
· P0171 System too Lean (Bank 1)
· P0172 System too Rich (Bank 1)
· P0173 Fuel Trim Malfunction (Bank 2)
· P0174 System too Lean (Bank 2)
· P0175 System too Rich (Bank 2)
· P0176 Fuel Composition Sensor Circuit Malfunction
· P0177 Fuel Composition Sensor Circuit Range/Performance
· P0178 Fuel Composition Sensor Circuit Low Input
· P0179 Fuel Composition Sensor Circuit High Input
· P0180 Fuel Temperature Sensor A Circuit Malfunction
· P0181 Fuel Temperature Sensor A Circuit Range/Performance
· P0182 Fuel Temperature Sensor A Circuit Low Input
· P0183 Fuel Temperature Sensor A Circuit High Input
· P0184 Fuel Temperature Sensor A Circuit Intermittent
· P0185 Fuel Temperature Sensor B Circuit Malfunction
· P0186 Fuel Temperature Sensor B Circuit Range/Performance
· P0187 Fuel Temperature Sensor B Circuit Low Input
· P0188 Fuel Temperature Sensor B Circuit High Input
· P0189 Fuel Temperature Sensor B Circuit Intermittent
· P0190 Fuel Rail Pressure Sensor Circuit Malfunction
· P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
· P0192 Fuel Rail Pressure Sensor Circuit Low Input
· P0193 Fuel Rail Pressure Sensor Circuit High Input
· P0194 Fuel Rail Pressure Sensor Circuit Intermittent
· P0195 Engine Oil Temperature Sensor Malfunction
· P0196 Engine Oil Temperature Sensor Range/Performance
· P0197 Engine Oil Temperature Sensor Low
· P0198 Engine Oil Temperature Sensor High
· P0199 Engine Oil Temperature Sensor Intermittent
· P0200 Injector Circuit Malfunction
· P0201 Injector Circuit Malfunction - Cylinder 1
· P0202 Injector Circuit Malfunction - Cylinder 2
· P0203 Injector Circuit Malfunction - Cylinder 3
· P0204 Injector Circuit Malfunction - Cylinder 4
· P0205 Injector Circuit Malfunction - Cylinder 5
· P0206 Injector Circuit Malfunction - Cylinder 6
· P0207 Injector Circuit Malfunction - Cylinder 7
· P0208 Injector Circuit Malfunction - Cylinder 8
· P0209 Injector Circuit Malfunction - Cylinder 9
· P0210 Injector Circuit Malfunction - Cylinder 10
· P0211 Injector Circuit Malfunction - Cylinder 11
· P0212 Injector Circuit Malfunction - Cylinder 12
· P0213 Cold Start Injector 1 Malfunction
· P0214 Cold Start Injector 2 Malfunction
· P0215 Engine Shutoff Solenoid Malfunction
· P0216 Injection Timing Control Circuit Malfunction
· P0217 Engine Overtemp Condition
· P0218 Transmission Over Temperature Condition
· P0219 Engine Overspeed Condition
· P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
· P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
· P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
· P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
· P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
· P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
· P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
· P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
· P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
· P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
· P0230 Fuel Pump Primary Circuit Malfunction
· P0231 Fuel Pump Secondary Circuit Low
· P0232 Fuel Pump Secondary Circuit High
· P0233 Fuel Pump Secondary Circuit Intermittent
· P0234 Engine Overboost Condition
· P0235 Turbocharger Boost Sensor A Circuit Malfunction
· P0236 Turbocharger Boost Sensor A Circuit Range/Performance
· P0237 Turbocharger Boost Sensor A Circuit Low
· P0238 Turbocharger Boost Sensor A Circuit High
· P0239 Turbocharger Boost Sensor B Malfunction
· P0240 Turbocharger Boost Sensor B Circuit Range/Performance
· P0241 Turbocharger Boost Sensor B Circuit Low
· P0242 Turbocharger Boost Sensor B Circuit High
· P0243 Turbocharger Wastegate Solenoid A Malfunction
· P0244 Turbocharger Wastegate Solenoid A Range/Performance
· P0245 Turbocharger Wastegate Solenoid A Low
· P0246 Turbocharger Wastegate Solenoid A High
· P0247 Turbocharger Wastegate Solenoid B Malfunction
· P0248 Turbocharger Wastegate Solenoid B Range/Performance
· P0249 Turbocharger Wastegate Solenoid B Low
· P0250 Turbocharger Wastegate Solenoid B High
· P0251 Injection Pump Fuel Metering Control “A” Malfunction (Cam/Rotor/Injector)
· P0252 Injection Pump Fuel Metering Control “A” Range/Performance (Cam/Rotor/
· P0253 Injection Pump Fuel Metering Control “A” Low (Cam/Rotor/Injector)
· P0254 Injection Pump Fuel Metering Control “A” High (Cam/Rotor/Injector)
· P0255 Injection Pump Fuel Metering Control “A” Intermittent (Cam/Rotor/Injector)
· P0256 Injection Pump Fuel Metering Control “B” Malfunction (Cam/Rotor/Injector)
· P0257 Injection Pump Fuel Metering Control “B” Range/Performance Injector)
· P0258 Injection Pump Fuel Metering Control “B” Low (Cam/R
· P0259 Injection Pump Fuel Metering Control “B” High (Cam/R
· P0260 Injection Pump Fuel Metering Control “B” Intermittent Injector)
· P0261 Cylinder I Injector Circuit Low
· P0262 Cylinder I Injector Circuit High
· P0263 Cylinder I Contribution/Balance Fault
· P0264 Cylinder 2 Injector Circuit Low
· P0265 Cylinder 2 Injector Circuit High
· P0266 Cylinder 2 Contribution/Balance Fault
· P0267 Cylinder 3 Injector Circuit Low
· P0268 Cylinder 3 Injector Circuit High
· P0269 Cylinder 3 Contribution/Balance Fault
· P0270 Cylinder 4 Injector Circuit Low
· P0271 Cylinder 4 Injector Circuit High
· P0272 Cylinder 4 Contribution/Balance Fault
· P0273 Cylinder 5 Injector Circuit Low
· P0274 Cylinder 5 Injector Circuit High
· P0275 Cylinder S Contribution/Balance Fault
· P0276 Cylinder 6 Injector Circuit Low
· P0277 Cylinder 6 Injector Circuit High
· P0278 Cylinder 6 Contribution/Balance Fault
· P0279 Cylinder 7 Injector Circuit Low
· P0280 Cylinder 7 Injector Circuit High
· P0281 Cylinder 7 Contribution/Balance Fault
· P0282 Cylinder 8 Injector Circuit Low
· P0283 Cylinder 8 Injector Circuit High
· P0284 Cylinder 8 Contribution/Balance Fault
· P0285 Cylinder 9 Injector Circuit Low
· P0286 Cylinder 9 Injector Circuit High
· P0287 Cylinder 9 Contribution/Balance Fault
· P0288 Cylinder 10 Injector Circuit Low
· P0289 Cylinder 10 Injector Circuit High
· P0290 Cylinder 10 Contribution/Balance Fault
· P0291 Cylinder 11 Injector Circuit Low
· P0292 Cylinder 11 Injector Circuit High
· P0293 Cylinder 11 Contribution/Balance Fault
· P0294 Cylinder 12 Injector Circuit Low
· P0295 Cylinder 12 Injector Circuit High
· P0296 Cylinder 12 Contribution/Range Fault
Ignition System or Misfire
· P0300 Random/Multiple Cylinder Misfire Detected
· P0301 Cylinder 1 Misfire Detected
· P0302 Cylinder 2 Misfire Detected
· P0303 Cylinder 3 Misfire Detected
· P0304 Cylinder 4 Misfire Detected
· P0305 Cylinder 5 Misfire Detected
· P0306 Cylinder 6 Misfire Detected
· P0307 Cylinder 7 Misfire Detected
· P0308 Cylinder 8 Misfire Detected
· P0309 Cylinder 9 Misfire Detected
· P0311 Cylinder 11 Misfire Detected
· P0312 Cylinder 12 Misfire Detected
· P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
· P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
· P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
· P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
· P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
· P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
· P0327 Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)
· P0328 Knock Sensor 1 Circuit High Input (Bank I or Single Sensor)
· P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
· P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
· P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
· P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
· P0333 Knock Sensor 2 Circuit High Input (Bank 2)
· P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
· P0335 Crankshaft Position Sensor A Circuit Malfunction
· P0336 Crankshaft Position Sensor A Circuit Range/Performance
· P0337 Crankshaft Position Sensor A Circuit Low Input
· P0338 Crankshaft Position Sensor A Circuit High Input
· P0339 Crankshaft Position Sensor A Circuit Intermittent
· P0340 Camshaft Position Sensor Circuit Malfunction
· P0341 Camshaft Position Sensor Circuit Range/Performance
· P0342 Camshaft Position Sensor Circuit Low Input
· P0343 Camshaft Position Sensor Circuit High Input
· P0344 Camshaft Position Sensor Circuit Intermittent
· P0350 Ignition Coil Primary/Secondary Circuit Malfunction
· P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
· P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
· P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
· P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
· P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
· P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
· P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
· P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
· P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
· P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
· P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
· P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
· P0370 Timing Reference High Resolution Signal A Malfunction
· P0371 Timing Reference High Resolution Signal A Too Many Pulses
· P0372 Timing Reference High Resolution Signal A Too Few Pulses
· P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
· P0374 Timing Reference High Resolution Signal A No Pulses
· P0375 Timing Reference High Resolution Signal B Malfunction
· P0376 Timing Reference High Resolution Signal B Too Many Pulses
· P0377 Timing Reference High Resolution Signal B Too Few Pulses
· P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
· P0379 Timing Reference High Resolution Signal B No Pulses
· P0380 Glow Plug/Heater Circuit “A” Malfunction
· P0381 Glow Plug/Heater Indicator Circuit Malfunction
· P0382 Exhaust Gas Recirculation Flow Malfunction
· P0385 Crankshaft Position Sensor B Circuit Malfunction
· P0386 Crankshaft Position Sensor B Circuit Range/Performance
· P0387 Crankshaft Position Sensor B Circuit Low Input
· P0388 Crankshaft Position Sensor B Circuit High Input
· P0389 Crankshaft Position Sensor B Circuit Intermittent
Auxiliary Emission Control
· P0400 Exhaust Gas Recirculation Flow Malfunction
· P0401 Exhaust Gas Recirculation Flow Insufficient Detected
· P0402 Exhaust Gas Recirculation Flow Excessive Detected
· P0403 Exhaust Gas Recirculation Circuit Malfunction
· P0404 Exhaust Gas Recirculation Circuit Range/Performance
· P0405 Exhaust Gas Recirculation Sensor A Circuit Low
· P0406 Exhaust Gas Recirculation Sensor A Circuit High
· P0407 Exhaust Gas Recirculation Sensor B Circuit Low
· P0408 Exhaust Gas Recirculation Sensor B Circuit High
· P0410 Secondary Air Injection System Malfunction
· P0411 Secondary Air Injection System Incorrect Flow Detected
· P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
· P0413 Secondary Air Injection System Switching Valve A Circuit Open
· P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
· P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
· P0416 Secondary Air Injection System Switching Valve B Circuit Open
· P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
· P0418 Secondary Air Injection System Relay .A” Circuit Malfunction
· P0419 Secondary Air Injection System Relay “B. Circuit Malfunction
· P0420 Catalyst System Efficiency Below Threshold (Bank 1)
· P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
· P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
· P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
· P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
· P0430 Catalyst System Efficiency Below Threshold (Bank 2)
· P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
· P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
· P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
· P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
· P0440 Evaporative Emission Control System Malfunction
· P0441 Evaporative Emission Control System Incorrect Purge Flow
· P0442 Evaporative Emission Control System Leak Detected (small leak)
· P0443 Evaporative Emission Control System Purge Control Valve Circuit
· P0444 Evaporative Emission Control System Purge Control Valve Circuit
· P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
· P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
· P0447 Evaporative Emission Control System Vent Control Circuit Open
· P0448 Evaporative Emission Control System Vent Control Circuit Shorted
· P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
· P0450 Evaporative Emission Control System Pressure Sensor Malfunction
· P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
· P0452 Evaporative Emission Control System Pressure Sensor Low Input
· P0453 Evaporative Emission Control System Pressure Sensor High Input
· P0454 Evaporative Emission Control System Pressure Sensor Intermittent
· P0455 Evaporative Emission Control System Leak Detected (gross leak)
· P0460 Fuel Level Sensor Circuit Malfunction
· P0461 Fuel Level Sensor Circuit Range/Performance
· P0462 Fuel Level Sensor Circuit Low Input
· P0463 Fuel Level Sensor Circuit High Input
· P0464 Fuel Level Sensor Circuit Intermittent
· P0465 Purge Flow Sensor Circuit Malfunction
· P0466 Purge Flow Sensor Circuit Range/Performance
· P0467 Purge Flow Sensor Circuit Low Input
· P0468 Purge Flow Sensor Circuit High Input
· P0469 Purge Flow Sensor Circuit Intermittent
· P0470 Exhaust Pressure Sensor Malfunction
· P0471 Exhaust Pressure Sensor Range/Performance
· P0472 Exhaust Pressure Sensor Low
· P0473 Exhaust Pressure Sensor High
· P0474 Exhaust Pressure Sensor Intermittent
· P0475 Exhaust Pressure Control Valve Malfunction
· P0476 Exhaust Pressure Control Valve Range/Performance
· P0477 Exhaust Pressure Control Valve Low
· P0478 Exhaust Pressure Control Valve High
· P0479 Exhaust Pressure Control Valve Intermittent
· P0480 Cooling Fan I Control Circuit Malfunction
· P0481 Cooling Fan 2 Control Circuit Malfunction
· P0482 Cooling Fan 3 Control Circuit Malfunction
· P0483 Cooling Fan Rationality Check Malfunction
· P0484 Cooling Fan Circuit Over Current
· P0485 Cooling Fan Power/Ground Circuit Malfunction
Speed and Idle Control
· P0500 Vehicle Speed Sensor Malfunction
· P0501 Vehicle Speed Sensor Range/Performance
· P0502 Vehicle Speed Sensor Low Input
· P0503 Vehicle Speed Sensor Intermittent/Erratic/High
· P0505 Idle Control System Malfunction
· P0506 Idle Control System RPM Lower Than Expected
· P0507 Idle Control System RPM Higher Than Expected
· P0510 Closed Throttle Position Switch Malfunction
· P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
· P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
· P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
· P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
· P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
· P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
· P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
· P0533 A/C Refrigerant Pressure Sensor Circuit High Input
· P0534 Air Conditioner Refrigerant Charge Loss
· P0550 Power Steering Pressure Sensor Circuit Malfunction
· P0551 Power Steering Pressure Sensor Circuit Range/Performance
· P0552 Power Steering Pressure Sensor Circuit Low Input
· P0553 Power Steering Pressure Sensor Circuit High Input
· P0554 Power Steering Pressure Sensor Circuit Intermittent
· P0560 System Voltage Malfunction
· P0561 System Voltage Unstable
· P0562 System Voltage Low
· P0563 System Voltage High
· P0565 Cruise Control On Signal Malfunction
· P0566 Cruise Control Off Signal Malfunction
· P0567 Cruise Control Resume Signal Malfunction
· P0568 Cruise Control Set Signal Malfunction
· P0569 Cruise Control Coast Signal Malfunction
· P0570 Cruise Control Accel Signal Malfunction
· P0571 Cruise Control/Brake Switch A Circuit Malfunction
· P0572 Cruise Control/Brake Switch A Circuit Low
· P0573 Cruise Control/Brake Switch A Circuit High
· P0574 Cruise Control Related Malfunction
· P0575 Cruise Control Related Malfunction
· P0576 Cruise Control Related Malfunction
· P0578 Cruise Control Related Malfunction
· P0579 Cruise Control Related Malfunction
· P0580 Cruise Control Related Malfunction
Computer Output Circuit
· P0600 Serial Communication Link Malfunction
· P0601 Internal Control Module Memory Check Sum Error
· P0602 Control Module Programming Error
· P0603 Internal Control Module Keep Alive Memory (KAM) Error
· P0604 Internal Control Module Random Access Memory (RAM) Error
· P0605 Internal Control Module Read Only Memory (ROM) Error
· P0606 PCM Processor Fault
· P0608 Control Module VSS Output “A” Malfunction
· P0609 Control Module VSS Output “B” Malfunction
· P0620 Generator Control Circuit Malfunction
· P0621 Generator Lamp “L” Control Circuit Malfunction
· P0622 Generator Field “F” Control Circuit Malfunction
· P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
· P0654 Engine RPM Output Circuit Malfunction
· P0655 Engine Hot Lamp Output Control Circuit Malfunction
· P0656 Fuel Level Output Circuit Malfunction
Transmission
· P0700 - Transmission Control System Malfunction
· P0701 - Transmission Control System Range/Performance
· P0702 - Transmission Control System Electrical
· P0703 - Torque Converter/Brake Switch B Circuit Malfunction
· P0704 - Clutch Switch Input Circuit Malfunction
· P0705 - Transmission Range Sensor Circuit malfunction (PRNDL Input)
· P0706 - Transmission Range Sensor Circuit Range/Performance
· P0707 - Transmission Range Sensor Circuit Low Input
· P0708 - Transmission Range Sensor Circuit High Input
· P0709 - Transmission Range Sensor Circuit Intermittent
· P0710 - Transmission Fluid Temperature Sensor Circuit Malfunction
· P0711 - Transmission Fluid Temperature Sensor Circuit Range/Performance
· P0712 - Transmission Fluid Temperature Sensor Circuit Low Input
· P0713 - Transmission Fluid Temperature Sensor Circuit High Input
· P0714 - Transmission Fluid Temperature Sensor Circuit Intermittent
· P0715 - Input/Turbine Speed Sensor Circuit Malfunction
· P0716 - Input/Turbine Speed Sensor Circuit Range/Performance
· P0717 - Input/Turbine Speed Sensor Circuit No Signal
· P0718 - Input/Turbine Speed Sensor Circuit Intermittent
· P0719 - Torque Converter/Brake Switch B Circuit Low
· P0720 - Output Speed Sensor Circuit Malfunction
· P0721 - Output Speed Sensor Range/Performance
· P0722 - Output Speed Sensor No Signal
· P0723 - Output Speed Sensor Intermittent
· P0724 - Torque Converter/Brake Switch B Circuit High
· P0725 - Engine Speed input Circuit Malfunction
· P0726 - Engine Speed Input Circuit Range/Performance
· P0727 - Engine Speed Input Circuit No Signal
· P0728 - Engine Speed Input Circuit Intermittent
· P0730 - Incorrect Gear Ratio
· P0731 - Gear I Incorrect ratio
· P0732 - Gear 2 Incorrect ratio
· P0733 - Gear 3 Incorrect ratio
· P0734 - Gear 4 Incorrect ratio
· P0735 - Gear 5 Incorrect ratio
· P0736 - Reverse incorrect gear ratio
· P0740 - Torque Converter Clutch Circuit Malfunction
· P0741 - Torque Converter Clutch Circuit Performance or Stuck Off
· P0742 - Torque Converter Clutch Circuit Stock On
· P0743 - Torque Converter Clutch Circuit Electrical
· P0744 - Torque Converter Clutch Circuit Intermittent
· P0745 - Pressure Control Solenoid Malfunction
· P0746 - Pressure Control Solenoid Performance or Stuck Off
· P0747 - Pressure Control Solenoid Stuck On
· P0748 - Pressure Control Solenoid Electrical
· P0749 - Pressure Control Solenoid Intermittent
· P0750 - Shift Solenoid A Malfunction
· P0751 - Shift Solenoid A Performance or Stuck Off
· P0752 - Shift Solenoid A Stuck On
· P0753 - Shift Solenoid A Electrical
· P0754 - Shift Solenoid A Intermittent
· P0755 - Shift Solenoid B Malfunction
· P0756 - Shift Solenoid B Performance or Stock Off
· P0757 - Shift Solenoid B Stuck On
· P0758 - Shift Solenoid B Electrical
· P0759 - Shift Solenoid B Intermittent
· P0760 - Shift Solenoid C Malfunction
· P0761 - Shift Solenoid C Performance or Stuck Off
· P0762 - Shift Solenoid C Stuck On
· P0763 - Shift Solenoid C Electrical
· P0764 - Shift Solenoid C Intermittent
· P0765 - Shift Solenoid D Malfunction
· P0766 - Shift Solenoid D Performance or Stuck Off
· P0767 - Shift Solenoid D Stuck On
· P0768 - Shift Solenoid D Electrical
· P0769 - Shift Solenoid D Intermittent
· P0770 - Shift Solenoid E Malfunction
· P0771 - Shift Solenoid E Performance or Stuck Off
· P0772 - Shift Solenoid E Stuck On
· P0773 - Shift Solenoid E Electrical
· P0774 - Shift Solenoid E Intermittent
· P0780 - Shift Malfunction
· P0781 - 1-2 Shift Malfunction
· P0782 - 2-3 Shift Malfunction
· P0783 - 3-4 Shift Malfunction
· P0784 - 4-5 Shift Malfunction
· P0785 - Shift/Timing Solenoid Malfunction
· P0786 - Shift/Timing Solenoid Range/Performance
· P0787 - Shift/Timing Solenoid Low
· P0788 - Shift/Timing Solenoid High
· P0789 - Shift/Timing Solenoid Intermittent
· P0790 - Normal/Performance Switch Circuit Malfunction
· P0801 - Reverse Inhibit Control Circuit Malfunction
· P0803 - 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
· P0804 - 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
Ford OBDII Diagnostic Trouble Codes
· P1000 - OBD-II Monitor Testing Incomplete
· P1001 - KOER Test Cannot Be Completed
· P1039 - Vehicle Speed Signal Missing or Improper
· P1051 - Brake Switch Signal Missing or Improper
· P1100 - Mass Air Flow Sensor Intermittent
· P1101 - Mass Air Flow Sensor out of Self-Test? Range
· P1112 - Intake Air Temperature Sensor Intermittent
· P1116 - Engine Coolant Temperature Sensor is out of Self-Test? Range
· P1117 - Engine Coolant Temperature Sensor Intermittent
· P1120 - Throttle Position Sensor out of range
· P1121 - Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
· P1124 - Throttle Position Sensor out of Self-Test? Range
· P1125 - Throttle Position Sensor Intermittent
· P1127 - Heated Oxygen Sensor Heater not on During KOER Test
· P1128 - Heated Oxygen Sensor Signals reversed
· P1129 - Heated Oxygen Sensor Signals reversed
· P1130 - Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1
· P1131 - Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
· P1132 - Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
· P1135 - Ignition Switch Signal Missing or Improper
· P1137 - Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
· P1138 - Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
· P1150 - Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2
· P1151 - Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
· P1152 - Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
· P1157 - Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
· P1158 - Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
· P1220 - Series Throttle Control fault
· P1224 - Throttle Position Sensor B out of Self-Test? Range
· P1230 - Power to Fuel Pump Circuit
· P1231 - High Speed Fuel Pump Relay activated
· P1232 - Low Speed Fuel Pump Primary circuit failure
· P1233 - Fuel Pump Driver Module off-line
· P1234 - Fuel Pump Driver Module off-line
· P1235 - Fuel Pump Control out of range
· P1236 - Fuel Pump Control out of range
· P1237 - Fuel Pump Secondary circuit fault
· P1238 - Fuel Pump Secondary circuit fault
· P1250 - Lack of Power to FPRC Solenoid
· P1260 - Theft Detected - Engine Disabled
· P1270 - Engine RPM or Vehicle Speed Limiter Reached
· P1288 - Cylinder Head Temperature Sensor out of Self-Test? Range
· P1289 - Cylinder Head Temperature Sensor Signal Greater Than Self-Test? Range
· P1290 - Cylinder Head Temperature Sensor Signal Less Than Self-Test? Range
· P1299 - Cylinder Head Temperature Sensor Detected Engine Overheating Condition
· P1309 - Misfire Detection Monitor not enabled
· P1351 - Ignition Diagnostic Monitor circuit Input fault
· P1352 - Ignition Coil A - Primary circuit fault
· P1353 - Ignition Coil B - Primary circuit fault
· P1354 - Ignition Coil C - Primary circuit fault
· P1355 - Ignition Coil D - Primary circuit fault
· P1356 - Loss of Ignition Diagnostic Module Input to PCM
· P1358 - Ignition Diagnostic Monitor Signal out of Self-Test? Range
· P1359 - Spark Output circuit fault
· P1364 - Ignition Coil Primary circuit fault
· P1380 - VCT Solenoid Valve circuit Short or Open
· P1381 - Cam Timing Advance is excessive
· P1383 - Cam Timing Advance is excessive
· P1390 - Octane Adjust out of Self-Test? Range
· P1400 - Differential Pressure Feedback Electronic Sensor circuit Low Voltage
· P1401 - Differential Pressure Feedback Electronic Sensor circuit High Voltage
· P1403 - Differential Pressure Feedback Electronic Sensor Hoses Reversed
· P1405 - Differential Pressure Feedback Electronic Sensor circuit Upstream Hose
· P1406 - Differential Pressure Feedback Electronic Sensor circuit Downstream Hose
· P1407 - EGR No Flow Detected
· P1408 - EGR Flow out of Self-Test? Range
· P1409 - EGR Vacuum Regulator circuit malfunction
· P1409 - Electronic Vacuum Regulator Control circuit fault
· P1410 - EGR Barometric Pressure Sensor VREF Voltage
· P1411 - Secondary Air is not being diverted
· P1413 - Secondary Air Injection System Monitor circuit Low Voltage
· P1414 - Secondary Air Injection System Monitor circuit High Voltage
· P1442 - Secondary Air Injection System Monitor circuit High Voltage
· P1443 - Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
· P1444 - Purge Flow Sensor circuit Input Low
· P1445 - Purge Flow Sensor circuit Input High
· P1450 - Inability of Evaporative Emission Control System to Bleed Fuel Tank
· P1451 - EVAP Control System Canister Vent Solenoid Circuit Malfunction
· P1452 - Inability of Evaporative Emission Control System to Bleed Fuel Tank
· P1455 - Substantial Leak or Blockage in Evaporative Emission Control System
· P1460 - Wide Open Throttle Air Conditioning Cutoff circuit malfunction
· P1461 - Air Conditioning Pressure Sensor circuit Low Input
· P1462 - Air Conditioning Pressure Sensor circuit high Input
· P1463 - Air Conditioning Pressure Sensor Insufficient Pressure change
· P1464 - ACCS to PCM High During Self-Test?
· P1469 - Low Air Conditioning Cycling Period
· P1473 - Fan Secondary High with Fans Off
· P1474 - Low Fan Control Primary circuit
· P1479 - High Fan Control Primary circuit
· P1480 - Fan Secondary Low with Low Fans On
· P1481 - Fan Secondary Low with High Fans On
· P1483 - Power to Cooling Fan Exceeded Normal Draw
· P1484 - Variable Load Control Module Pin 1 Open
· P1500 - Vehicle Speed Sensor Intermittent
· P1501 - Programmable Speedometer & Odometer Module/Vehicle Speed Sensor *Intermittent circuit-failure
· P1502 - Invalid or Missing Vehicle Speed Message or Brake Data
· P1504 - Intake Air Control circuit malfunction
· P1505 - Idle Air Control System at Adaptive Clip
· P1506 - Idle Air Control Over Speed Error
· P1507 - Idle Air Control Under Speed Error
· P1512 - Intake Manifold Runner Control Stuck Closed
· P1513 - Intake Manifold Runner Control Stuck Closed
· P1516 - Intake Manifold Runner Control Input Error
· P1517 - Intake Manifold Runner Control Input Error
· P1518 - Intake Manifold Runner Control fault - Stuck Open
· P1519 - Intake Manifold Runner Control Stuck Open
· P1520 - Intake Manifold Runner Control circuit fault
· P1519 - Intake Manifold Runner Control fault - Stuck Closed
· P1520 - Intake Manifold Runner Control fault
· P1530 - Clutch Circuit
· P1537 - Intake Manifold Runner Control Stuck Open
· P1538 - Intake Manifold Runner Control Stuck Open
· P1539 - Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw
· P1549 - Intake Manifold Temperature Valve Vacuum Actuator Connection
· P1550 - Power Steering Pressure Sensor out of Self-Test? Range
· P1605 - PCM Keep Alive Memory Test Error
· P1625 - Voltage to Vehicle Load Control Module Fan circuit not detected
· P1626 - Voltage to Vehicle Load Control Module circuit not detected
· P1650 - Power Steering Pressure Switch out of Self-Test? Range
· P1651 - Power Steering Pressure Switch Input fault
· P1700 - Transmission system problems
· P1701 - Reverse Engagement Error
· P1702 - Transmission system problems
· P1703 - Brake On/Off Switch out of Self-Test? Range
· P1704 - Transmission system problems
· P1705 - Manual Lever Position Sensor out of Self-Test? Range
· P1709 - Park or Neutral Position Switch out of Self-Test? Range
· P1710 - Transmission system problems
· P1711 - Transmission Fluid Temperature Sensor out of Self-Test? Range
· P1713 thru P172 - Transmission system problems
· P1729 - 4×4 Low Switch Error
· P1740 - Transmission system problems
· P1741 - Torque Converter Clutch Control Error
· P1742 - Torque Converter Clutch Solenoid Faulty
· P1743 - Torque Converter Clutch Solenoid Faulty
· P1744 - Torque Converter Clutch System Stuck in Off Position
· P1745 - Transmission system problems
· P1746 - Electronic Pressure Control Solenoid - Open circuit
· P1747 - Electronic Pressure Control Solenoid - Short circuit
· P1749 - Electronic Pressure Control Solenoid Failed Low
· P1751 - Shift Solenoid No. 1 Performance
· P1754 - Coast Clutch Solenoid circuit malfunction
· P1756 - Shift Solenoid No. 2 Performance
· P1760 - Transmission system problems
· P1761 - Shift Solenoid No. 3 Performance
· P1762 - Transmission system problems
· P1767 - Transmission system problems
· P1780 - Transmission Control Switch circuit is out of Self-Test? Range
· P1781 - 4×4 Low Switch is out of Self-Test? Range
· P1783 - Transmission Over-Temperature? Condition
· P1784 - Transmission system problems
· P1785 - Transmission system problems
· P1786 - Transmission system problems
· P1787 - Transmission system problems
· P1788 - Transmission system problems
· P1789 - Transmission system problems
· P1900 - Transmission system problems
File Type: doc
Old Feb 3, 2007 | 12:45 AM
PATAN's Avatar
awesome thanks a lot, I am doing copy/paste on my pc.
thanks!
I keep getting the error codes p0171 and 74 with the race tune, could it be because it is pretty cold weather and the tunes are so detailed that a little change in temp can actually generate a error code?
I was driving the car with the race tune man, what a blast, it feels like a totally different car.
Old Feb 3, 2007 | 04:40 AM
SteelTownStang's Avatar
Patan, Yes, it could be... I'd still call Doug though.
Mark, Awesome info. Thanks
Old Aug 1, 2007 | 07:48 PM
SilverPOISON's Avatar
how do you fix P0600
Old Jan 26, 2008 | 07:32 AM
Emu Hunter's Avatar
As they say, there are no stupid question in life, sooo... just to make sure I understand... Do I need to keep my handheld programmer (xcal2) plugged in while operating the vehicle in order to register or look for any error codes? Or are they stored and outputted when I plug the xcal2 into the connection. I'm just asking how you take the readings exactly. I should probably go read the instructions that came with the unit I guess..
Old Jan 26, 2008 | 03:13 PM
AlloyGT's Avatar
The codes will be stored...when you plug in the XCal, on the menu there is a section "Read DTC codes", or something like that. You don't need to leave the XCal plugged in.
Old Jan 26, 2008 | 07:47 PM
Emu Hunter's Avatar
Thanks Tim. I think I'll read the codes tomorrow before putting the car back under its blanky.
Old Jan 26, 2008 | 09:05 PM
Cobrakev's Avatar
Make sure you have all the pipe connections tight. It might be sucking air around the connections.
Old Jan 27, 2008 | 02:45 PM
06GT4RAD's Avatar
The codes 171 and 174 are do to unmetered air after the MAF sensor you most likely have a air leak somewhere within the CAI. Check all fitting and connections to make sure they are sealed properly.
Old Nov 5, 2023 | 01:30 PM
05stangkc's Avatar
KC
JPC
2012-2013 BOSS 302
May 25, 2012 08:47 PM
347strokin
Oct 4, 2007 09:55 PM
LurchII
Sep 30, 2007 08:29 PM
Geos05GTvert
Apr 4, 2007 08:33 PM
