Dead Battery Problem Solved
Old Sep 6, 2008 | 01:55 PM
  #61
frdtch05gt's Avatar
My car isn't my daily driver, sits all week and fires right over on the weekend with no problems. I don't lock it with the remote in the garage so that the alarm won't drain it down. It can sit for many weeks during the winter and not drain down as well.
Old Sep 6, 2008 | 05:04 PM
  #62
06GT4RAD's Avatar
Mine is the same way but it sometimes sits for a few weeks at a time without being driven and like I said I finally became a victim of this issue a couple weeks ago. I charged the battery and then drove the car for a couple hours and have not had the issue again. However i think i am most likley going to upgrade to the 850CCA battery
Old Sep 8, 2008 | 06:32 AM
  #63
StangRalle's Avatar
Aaaaaaaaaaaaaaaaaaaaaahhhhhhhhh Battery dead again... I'm really getting pi$$ed...
My original M-craft battery was fried after 2 years. Then I bought a replacement from Varta. It worked great until today.
I had my Stang 2 weeks parked in my garage and when I tried it today... DEAD...
I am charging the bat. now and see if it works after.
Old Sep 8, 2008 | 06:45 AM
  #64
metroplex's Avatar
The upgrade to a Group 65 (what you're referring to as a 850 CCA) will not solve your problem, it will just last a tiny bit longer.
Old Sep 8, 2008 | 06:47 AM
  #65
StangRalle's Avatar
Originally Posted by metroplex
The upgrade to a Group 65 (what you're referring to as a 850 CCA) will not solve your problem, it will just last a tiny bit longer. I suspect there is a faulty relay somewhere or the SJB is defective, allowing the Shaker amps to continue drawing current after the key is removed.
If that would be the case, what would be the resolution?
Replace the SJB?
Old Sep 8, 2008 | 10:27 AM
  #66
metroplex's Avatar
Replace the SJB?
I'm not sure what is wrong with the car's electrical system. It could either be the Shaker 500, SJB, Active Anti-Theft or a combination of all 3. However, the stock battery should far outlast 30 days without being charged and with the alarm activated.
Old Sep 8, 2008 | 10:31 AM
  #67
StangRalle's Avatar
I don't know man. I have the shaker1000 in my car. Anyhow, I took my Stang after a few hours of battery charging for a spin to recharge the battery a bit.
After, I put her in my garage and did not lock her. So lets see tomorrow if I can crank her up.
Old Sep 8, 2008 | 07:28 PM
  #68
karman's Avatar
You guys might want to check out this thread I started.
Lots of info.
http://forums.bradbarnett.net/showthread.php?t=472337
Old Sep 9, 2008 | 01:17 AM
  #69
StangRalle's Avatar
Lots of info.
Thanks man. Checked it out. But won't really help resolving this issue here.
Old Sep 9, 2008 | 07:49 AM
  #70
2Slack's Avatar
I have been experiencing the same problem since last December. I have a second car that became my daily driver and left the 05 GT at a relative’s house for a few weeks. When I went to pick it up, dead battery. I thought I may have left my interior light on and as it was a couple of months I decided to purchase a new battery. I then left the car at another relative while I made renovations to my driveway and when I went to pick it up again, dead battery. I used my jump-pack and she turned right over. I started driving the car on a daily basis with no problem but if I miss 2 or 3 days, bring out the jump-pack which is now stationed in my car.
I had the car to Ford and they put a meter on the battery but found no unusual drain. I do not have the shaker. I have tried turning off the stereo (custom unit) and not locking the doors to no avail though the later seemed to work at first.
It seems the only solution is to drive the car everyday as she’s a jealous mistress.
Old Sep 9, 2008 | 07:58 AM
  #71
StangRalle's Avatar
Exactly. She seemes to be VERY jealous!
I'll remove the battery again for the winter and charge it from here to then.
lakersfreak
Jun 13, 2022 12:29 AM
Rando
Aug 25, 2021 11:12 AM
boz
Oct 1, 2015 04:47 PM
mx5jhb
Sep 30, 2015 04:44 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
