Dead Battery Already???
Old Nov 27, 2007 | 12:10 PM
  #101
Ranger's Avatar
Originally Posted by Mtang78
I asked the dealer about the dead battery issue yesterday when I had the car in for the brake fluid damage issue. I was told that all of these new Fords - not just Mustangs - do the same thing. If they are not driven for at least 1 hour a week, the battery drains down. They claim that the problem is the car has to retain a certain amount of memory to operate and that drains down the battery. They say it doesn't have anything to do with the stereo or alarm systems - it is what memory the car has to have to operate.
Just had my first issue regarding a dead battery last week. Have had car for 2 3/4 years with 23,000 on it and this was the first time it wouldn't start. Car had sat for 14 days prior to this.
Pulled the battery and took it to the dealer - it had a bad cell, so I came home with a new one. Had the charging system checked and its putting out ok. Got a Battery Tender since with winter coming, it does sit for longer periods.
Old Nov 27, 2007 | 05:21 PM
  #102
Dougxox's Avatar
Just had my battery replaced, it died on the way back from Wisconsin. Started ok in the morning, had to have it jumped after stoping once the second time had to call roadside asst. he tried to use the jumper box that did not work and had to use the truck. 300 miles later got home, shut it off and tried to start it....dead. bad cell.
Old Nov 27, 2007 | 05:27 PM
  #103
theedge67's Avatar
At least it got you home!
Old Nov 27, 2007 | 05:34 PM
  #104
Dougxox's Avatar
With the remote start there is a "convenience" button where you can hit it and remove the keys and the engine remains running. Had to do that to get gas.
Old Nov 27, 2007 | 06:56 PM
  #105
Stoenr's Avatar
Not recommended to leave car running while pumping gas. Unless you want he gas cap light to come on.........
Old Nov 27, 2007 | 07:35 PM
  #106
Dougxox's Avatar
Only other choice at the time was to wait another hour for roadside asst. to show up.
Old Nov 27, 2007 | 09:54 PM
  #107
theedge67's Avatar
I've fueled it a couple of times with the engine running, mostly when it is super cold out and I just started it 2 minutes before. I've never seen the gas cap warning come on.
Old Nov 28, 2007 | 06:41 AM
  #108
Dougxox's Avatar
Maybe it goes off after you put the gas cap back on
lakersfreak
Jun 13, 2022 12:29 AM
mx5jhb
Sep 30, 2015 04:44 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
