Convertible. Only quarter/rear window power not working
Old Jun 22, 2021 | 10:59 PM
marcosMadrid's Avatar
Hello guys, happy to be here!
The two front windows work normally, and suddenly, the small quarter window of the drive is down, and does not respond to the roll-up signal... so my car sleeps with that window open...
Any idea? I guess its not about fuses, since the other windows work normally. This assumption sounds right?
I am having issues with the top too... there is any mechanism or detector or sensor that could override the quarter windows to rollup? The top its closed, but maybe the car think it is not?
Thank u gents!
Old Jun 23, 2021 | 08:29 AM
NC14GT's Avatar
I think you nailed it with the convertible top issue. With the rear windows down, the top should function normally. Since the top is not going down, it is definitely reading the rear windows as being up. It's almost like it needs a re-set of some type.
Uneducated ideas here from me but no harm in trying if you feel like it. Maybe replace the fuse(s) just to see if it helps?? Perhaps the battery?? Hopefully someone will respond with the technical know how instead of my guesses.
Old Jun 23, 2021 | 12:24 PM
For whatever reason, the car thinks the convertible top is open or moving. I followed this procedure I found to override manually and indeed, the rear quarter window opens
Manual Override
The rear quarter window switch will not operate when:
• the convertible top is moving • the convertible top is not completely up or down.
The rear quarter windows can be manually raised if the switch does not operate when the convertible top is completely up or down.
The following procedure must be performed within two minutes:
1. Switch the ignition off, then back on.
2. Press the rear window switch down three times.
3. Switch the ignition off, then back on.
4. Pull the rear window switch up and hold it for three seconds. The rear windows will begin to start moving up.
Now the next question is... why the car thinks the convertible top is open?
Old Jun 23, 2021 | 01:00 PM
SpectreH's Avatar
I would think there must be sensors or switches that are engaged when the top is fully up or down that are defective or stuck.
https://iihs.net/fsm/?d=1096&f=Conve...Switch.pdf&p=1
Old Dec 4, 2021 | 06:08 PM
Davedwin's Avatar
Oh my gosh, dude, I can't thank you enough for posting this. I've spent the past 24 hours working on this. I finally broke down and scheduled an appointment with the dealer. Problem with that is they can't get me in for two weeks.
My biggest fear was not getting the windows up while I wait. Now I'll order the repair manual and see if I can fix it myself before paying the dealer service department who didn't seem to care that my windows were stuck down and my top thought it was always open.
If I find a solution, I will be sure to come back here and post it here first.
Old Sep 2, 2023 | 07:06 PM
dboy's Avatar
2016 convertible top stuck down
[QUOTE=NC14GT;7062486]I think you nailed it with the convertible top issue. With the rear windows down, the top should function normally. Since the top is not going down, it is definitely reading the rear windows as being up. It's almost like it needs a re-set of some type.
only opens a little bit and closes the rear windows
Old Sep 2, 2023 | 07:18 PM
05stangkc's Avatar
[QUOTE=dboy;7078403]
No Worries,
I See Your New, This is an Older Post. See Upper Left Corner By Avatar.
So OP or Original Poster has Likely Solved Issue! If You Have a Mustang I Invite you To Post In Introductions with Some Pics!
https://themustangsource.com/forums/f650/
Welcome!
Mgb,
KC
Old Mar 24, 2024 | 02:13 PM
Hockeydad's Avatar
THANK YOU!
marcosMadrid your Manuel Override instructions worked perfectly. You saved me so much time and frustration. I just got done replacing my convertible top and was happy how it came out, but when I went to close the windows, the quarter windows didn't move. I'm so happy I found this thread.
Old Mar 24, 2024 | 02:27 PM
05stangkc's Avatar
Welcome!
Lots of Good Vert Info Here Too!
https://themustangsource.com/forums/f739/s-197-convertible-top-issues-lots-factory-shop-manual-pdfs-549940
KC
Also To The Folks Out There a Lot of The Time Your Info is as Close as Your Owners Manual!
Don't Have One! Free Pdf's Here!
https://themustangsource.com/forums/f897/
Old Apr 9, 2024 | 06:19 AM
asdrew's Avatar
Since this thread is still going, I'll add my 2 cents.
First, I wish I had the manual override instructions a year ago when this first happened for me.
Second, after many efforts, replaced parts, etc I discovered the cause and solution for issues with the quarter window not going up and/or the top not operating.
For me, they were intermittent and related to the SJB not registering input from the sensors that tell it that it is okay to move the window or top.
The SJB/fuse box is fairly easy to remove, one 10mm bolt and harness connectors.
I immediately noticed corroded pins so separated the case to get to the board itself. None of the electronic components appeared damaged and the pins were still in great shape.
A toothbrush (not Wifey's) and some contact cleaner or rubbing alcohol will get it all back in order and I did the harness connectors also.
Since re-installing the SJB the top and windows operate perfect every time, and several other vexing electrical gremlins no longer reside in my convertible.
SJB case
SJB back
Corroded pins
SJB board
Old Apr 15, 2024 | 02:00 PM
05stangkc's Avatar
@asdrew
Sorry Your Post Was Stuck in Moderation So Nobody Could View Until Now! Just Cause You Were Considered New With a Large Post!
I Bumped You From Newbie to Member So You Are Now Set!
The SJB Box & Water Intrusion are Often an Issue on These Cars! Thank You For Taking The Time For a Great Post!
KC
ADMIN
Old Apr 16, 2024 | 02:52 AM
asdrew's Avatar
Thanks KC, I'm moderator for the Ford Transit USA forum, so I understand. Thanks for all you do here!
Old Apr 24, 2024 | 09:42 PM
Hockeydad's Avatar
My micro switch was damaged
Replaced my top. Quarter windows would not respond, but the reset worked. Checked the mico-switch and found it was dangling loose, broken off. Luckily I was able to get one from a junk yard cheap $40 (they removed) and not it works perfectly. This has a connection to the right of your rear speaker in the back passenger seat area. It snakes behind the convertible top mechanism. It has two points of contact to keep it firm and in position. One is a small tube that fits through the metal plate and the second is a plastic stud for alignment. It is held in place with a T20 screw into the plastic tube. This screw is faced on the outside facing in, just under the quarter window glass. I used a finger wrench to fit in the small space. Make sure you stuff towels in the quarter panel space to prevent loosing the screw. I'll post both the good switch with screw in post, as well as my damaged one for reference. Hope this can help someone that has a problem with this switch.
Good switch w/mounting screw
Broken switch, pin and mounting tube broken off
Old Apr 26, 2024 | 10:16 AM
05stangkc's Avatar
You Were Blocked Again. Thought I Overrode it!
Anyhoo Unblocked Post & Thanks Again For Updating!
KC
Old May 31, 2025 | 10:34 AM
05stangkc's Avatar
Found This Quarter Window Kit on Ebay The Other Day!
Just an FYI For Quarter Glass Related Issues!
Search on Ebay Down The Road if Link Goes Bad!
Rear Quarter Window Regulator Repair Kit for Ford Mustang S197 2005-2014
https://ebay.us/m/z2EUsu
KC
Old May 31, 2025 | 11:03 AM
tukatz's Avatar
My right quarter window goes MOST of the way up after I raise the top and raise the quarter windows. This is in the 2020 GT. The left one works properly. The right one leaves a gap at the top of about 1/2 - 3/4". If I operate the switch after I get going it will raise to closed. Any ideas?
Old May 31, 2025 | 03:06 PM
tukatz's Avatar
I should have mentioned that I can grab the top of the leading edge and pull it into the fully closed position. Also, I lowered the top and raised the rear quarter windows and it went all the way up.
Old Jun 1, 2025 | 05:47 AM
asdrew's Avatar
That could be how it is contacting the seal on the top, making it think it is closed all the way because of resistance. One of mine does that since I replaced the top on it and it is obvious that the top is not aligned just so. One of these days it will be addressed...
Old Jun 1, 2025 | 06:06 AM
tukatz's Avatar
Thanks, that makes sense. I'll just change my procedure and raise the rear quarter windows BEFORE raising the top.
Old Jun 1, 2025 | 12:40 PM
tukatz's Avatar
D..n!! Doesn't work. If you raise the rear windows and then try to raise the top, the rear windows go back down first.
