Changing fuel filter
Old May 9, 2010 | 08:12 PM
05RedGT's Avatar
How do you disconnect the fuel lines from the filter? The connectors look like they just pull apart but I can't get the lines off the filter.
Old May 9, 2010 | 10:36 PM
06GT's Avatar
You have to press down and hold the green areas of the connector, then they will slide right off. I found it helpful to use the flat of a flatblade screwdriver to help.
Old May 10, 2010 | 09:19 AM
05RedGT's Avatar
Thanks! I will give that a try.
Old May 10, 2010 | 05:48 PM
Cavero's Avatar
Advance Auto Parts also sells a tool to do it for like $5
Old May 10, 2010 | 06:15 PM
Seems like I read about relieving pressure in the lines first?
Old May 10, 2010 | 09:00 PM
Cavero's Avatar
just pop the gas cap and have a bucket under the fuel. It's at the lowest point in the system, so gravity's still going to push everything out of the lines that's already sitting in them.
Old May 11, 2010 | 03:31 AM
06GT's Avatar
Pull the fuel pump relay (underhood box, rearmost block in center row), then attempt to crank the car 2-3x.
Put the relay back in when you're done w/ the filter swap.
Old Sep 30, 2010 | 11:32 AM
RKNMACH's Avatar
That's the best way to relieve the pressure. When I changed my filter I couldn't get it to seat until I realized the morons at the dealer gave me the wrong size. Luckily I had another car to drive to get the right one.
Old Oct 24, 2010 | 08:05 PM
randy_tho's Avatar
I've changed it without releasing anything. It makes some mess but not too bad. Just have a pan to drain into. The relay pull would probably be fine and totally clean.
Autotooner
Nov 24, 2017 12:42 PM
ricky1728
Feb 11, 2016 07:25 PM
MustangConvert11
Sep 30, 2015 08:01 PM
DerekShiekhi
Sep 30, 2015 06:59 AM
southern stang
Sep 26, 2015 04:19 PM
