A/C not working
Old Mar 26, 2007 | 06:42 PM
hk2006's Avatar
A/C not working
I noticed today that my A/C is not working. Its blowing air but not cold. Anybody has any idea what this could be and what I can cheak before taking the car to the dealership? (prefer not to do it). Thanks!
Old Mar 26, 2007 | 07:46 PM
karman's Avatar
If you live as far north as I do (or more) the A/C may not come on until it gets warmer out.
Old Mar 27, 2007 | 12:48 AM
DynamicmustangGT's Avatar
I know this is going to sound weird but try the coolant level. when the car gets too cold the heat doesnt come out hot and the ac usually wont blow any air until the engine is warmer. otherwise take it in.
Old Mar 27, 2007 | 09:10 AM
hk2006's Avatar
It was 80 degrees outside yesterday and I drove the car about 10 miles but cold air never came out.
Old Mar 27, 2007 | 03:01 PM
boss429man's Avatar
Could be low on freon if thats the case you have a leak ,let Ford fix it under your warentee? could also be a cycle switch or the a/c clutch relay both should be warentee? Sometimes the the clutch will not ingage if it been a long time since it's been used . hope this helps I could get more into it bit need to know your skills ?
Old Mar 27, 2007 | 03:09 PM
GottaHaveIt's Avatar
Same thing happened to me after like 2-3 months when I got my 05 GT never worked took in recharged and off we went , I've never checked my 07 yet. Take it in.
Old Mar 27, 2007 | 11:48 PM
Do the 05+ have freone anymore, I thought they went with ammonium nitrate. Anyway back on track you might want to try the dealership, it might be something with the blower unit you said 80 degrees you might want to chek the heat, they tend to have the same blower unit
^ assuming you didnt try the heat because it was 80 degrees
Old Mar 28, 2007 | 08:14 AM
hk2006's Avatar
I used AC last time 6 month ago, so its been a while, you might be right in terms of cluth not engaging. How i can check to see whether the clutch is engaging or not, thanks
Old Mar 28, 2007 | 08:16 AM
hk2006's Avatar
The heat is OK, the AC button light comes up but blows hot or regular air, no cold at all.
Old Mar 28, 2007 | 08:29 AM
G.T's Avatar
G.T
you can hear the AC clutch engaging and disengaging.. and it usually causes your RPM to fluctuate a little bit
you can even log that with any decent OBD tool, an SCT or a Predator.
i think you're out of freone
Old Mar 28, 2007 | 08:36 AM
hk2006's Avatar
any way to check the freon? I really don't want to take the car to dealership unless absolutely necessary.
Old Mar 28, 2007 | 08:43 AM
G.T's Avatar
G.T
not unless you have an appropriate pressure tester.
i'm sure you can take it just about anywhere and have them check your refrigerant level
Old Mar 28, 2007 | 01:14 PM
boss429man's Avatar
Turn on the a/c with the car running look at the front of the compressor if it's moving then the unit is on.If not the clutch is not on. A ouick try is a freon kit from autozone follow the instution as you put the freon in the clutch should ingage if the system low. I used freon because its universal for the a/c coolant.tried not to confuse anyone? If your not sure and you have a freind who a tech or you live in the Seminole ,FL area ask him to help .remember a/c is a closed system so if it low it has a leak!!!If you live in the seminole area p/m me and I will help you.
Old Mar 28, 2007 | 02:05 PM
RKNMACH's Avatar
I'm taking mine in to the dealer tomorrow to find out why the A/C is not putting out cold air. All I am getting is warm air. I'll let you know what they find.
Old Mar 29, 2007 | 10:39 PM
I'm guessing freone too at this point. Strange that this is happening, since everyhting seems to be working perfectly fine, as long as air is coming out. Any puddles under the car? Maybe your dealership didn't fill it upon arrival because thats a dealership fill, not a factory deal
Old Mar 29, 2007 | 10:41 PM
as long as it is freone and not ammonium nitrate which I thought I heard that they use now, at least I know hondas do
Old Mar 30, 2007 | 08:28 PM
karman's Avatar
As far as I know they both use tetrafluorothane R134 (known as R134)
It works pretty much like Freon.
Ammonium nitrate is what Timothy McVie used to blow up the building in Oklahoma.
Old Mar 30, 2007 | 08:40 PM
Mike McRann's Avatar
take it to the dealer and let them deal with it. that's what the warrenty is for.
Old Mar 31, 2007 | 12:01 PM
boss429man's Avatar
Yes it's 134 just tring to keep it simple.
